Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Gmade R1 body tilts to left when accelerating
Old 04-21-2017, 09:24 AM   #1
Default Gmade R1 body tilts to left when accelerating
Hello guys,
This is my first post and I have recently finished building the kit.
I realized that the R1 body tilts to one side when it's moving and I was wondering if you guys have an idea on how to reduce the tilt.
I will post some pictures when I get home.
Thanks!
woovid is offline   Reply With Quote
Old 04-21-2017, 09:42 AM   #2
Default Re: Gmade R1 body tilts to left when accelerating
If the front tire is lifting it's called torque twist, mine love to do that
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 04-21-2017, 10:09 AM   #3
If you reverse it should lean the other way.
Brake Weight is offline   Reply With Quote
Old 04-21-2017, 10:09 AM   #4
Hang up and Drive
The front tires are fine. The body tilts left when it's moving forward and tilts right when it's reversing. I know that this is normal but I wanted to know if there was a way to eliminate tilting.
Old 04-21-2017, 10:17 AM   #5
You can get slightly stiffer springs or maybe thicker oil. Possibly swap out the plungers/discs in the shock itself to increase dampening.
Or swap out shocks. Have a look see through the subforum and see what others are running.
Old 04-21-2017, 10:29 AM   #6
Make up a set of sway bars.
Hang up and Drive
Old 04-23-2017, 10:59 AM   #7
Unfortunately it's got rather mushy suspension and torque twist hits the R1 hard. You could try stiffening the springs up but what does that really help? I honestly don't drive mine on flat ground enough to ever notice the torque twist.
GTSLOW is offline   Reply With Quote
Old 04-25-2017, 04:33 PM   #8
Natedog's Avatar
Hang up and Drive
That and/or move the suspension link mount locations around, outboard the shocks front and rear if there's room.
Yes, torque twist.
Old 04-25-2017, 04:37 PM   #9
Yes, torque twist.
Or sell it for a Wraith like I did
Old 04-30-2017, 02:52 AM   #10
Nooooooooooo..........
Fubar27 is offline   Reply With Quote
Old 06-29-2017, 10:17 AM   #11
supermoturd's Avatar
Torque twist for sure. It used to bother me, but it has never affected my crawling and now I hardly notice it.
supermoturd is offline   Reply With Quote
Old 09-28-2017, 09:39 PM   #12
This is a gold mine. The thread is very useful.
tech54K is offline   Reply With Quote
Gmade R1 body tilts to left when accelerating - Similar Threads
new servo....now its tilts full right on throttle?? SwampDawg Electronics 28 04-11-2014 11:23 AM
Motor stutters while accelerating... Dualdigger Electronics 5 09-17-2012 11:41 AM
Wraith Accelerating when transmitter is turned off Javelin Newbie General 7 07-13-2012 05:29 PM
Idle and accelerating motor sound?? raolguio Newbie General 2 09-30-2010 10:44 AM
