12-27-2017, 08:09 PM | #1 |
Pebble Pounder Join Date: Jan 2017 Location: Salt Lake City
| Yeti for a GOM
I'm debating selling my built up Yeti and building a GOM. I have been thinking about getting a bomber in place of the Yeti for a while now so that I can have a rig that crawls a little better. My yeti has all the bells and whistles including a 2 speed and I really love it but I've had it for a year and a half and I'd love to build something else. Am I going to regret the GOM? |
12-27-2017, 08:21 PM | #2 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: Yeti for a GOM
from the point of front suspension design, The advantage of IFS will be very stable in high speed bashing than solid axle. |
12-27-2017, 08:34 PM | #3 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Yeti for a GOM
A Bomber and a GOM will both crawl way more than “a little better” over a Yeti IMO. The Bomber for sure does, and I would be shocked if someone said otherwise about the GOM. You should sell the Yeti if you are done enjoying it or don’t enjoy it and add a Bomber or GOM to the garage. And is a better choice than Or Last edited by smog; 12-27-2017 at 08:36 PM. |
12-27-2017, 09:01 PM | #4 |
| Re: Yeti for a GOM
I still want a go fast rig but it doesn't need to be as crazy as the Yeti. Will the GOM hold up to some speed and a brushless sensored motor?
12-27-2017, 09:13 PM | #5 |
| Re: Yeti for a GOM
A Bomber will. I can’t speak for GOM in that department, it’s possible you might need some upgrades.
12-28-2017, 01:01 AM | #6 |
| Re: Yeti for a GOM If I were you( yes, I like go fast ) another good choice worth for your consideration will be The Losi Rock Rey kit version |
12-28-2017, 01:03 AM | #7 | |
| Re: Yeti for a GOM Quote:
Ive done a Rock Rey. It’s pretty much the same as the yeti but harder to work on and less parts available. I liked the yeti better. Sent from my iPhone using Tapatalk | |
12-28-2017, 01:14 AM | #8 |
| Re: Yeti for a GOM
Okay then maybe Bomber will be good for you. Can be very stable and fast and yet still crawl very well. Just like my Wraith ( very similar to bomber ) cheers |
12-28-2017, 06:01 AM | #9 |
| Re: Yeti for a GOM
I’m going to muddy things up here. You should build an IFS Bomber. Will crawl and go faster than the GOM or solid axle bomber. Hang up and Drive |
12-28-2017, 10:53 AM | #10 |
| Re: Yeti for a GOM |
12-28-2017, 11:01 AM | #11 |
| Re: Yeti for a GOM
Hear that ! My Yeti loves dollars, the Wraith has a bunch, but solid. I had a R1 and it was OK.... not bad, not great. Limited turning and upgrade parts is the Gmade downfall. Hang up and Drive |
12-28-2017, 12:44 PM | #12 |
Quarry Creeper Join Date: Sep 2017 Location: UK
| Re: Yeti for a GOM
I have a Yeti Score ( Brushless ) Bomber Brushless and Ive just built 2 x Brushed GOM. Keep the Yeti for bashing, neither the Bomber or GOM will come close. If going brushless I would get a Bomber over a GOM, GOM has some plastic gears in the transmission. The GOM does has a wider wheelbase and the weight distro is superb. Bomber has better parts out of the kit and better steering.
12-28-2017, 12:47 PM | #13 | |
Good info, do you know if you can get metal gears for the GOM? Sent from my iPhone using Tapatalk | |
12-28-2017, 02:09 PM | #14 |
| Re: Yeti for a GOM
I had those plastic gears in the R1brushless, 3s no wear or issues at all....robust gears. Its the shafts that will fail.
12-28-2017, 03:17 PM | #15 |
| Re: Yeti for a GOM
Well, I bought one. Any suggestions on upgrades right off the bat? Sent from my iPhone using Tapatalk |
12-28-2017, 03:27 PM | #16 |
12-28-2017, 03:46 PM | #17 |
| Re: Yeti for a GOM
Will a long can 540 motor fit in the GOM? https://holmeshobbies.com/motors/bru...motor-989.html |
Yeti for a GOM - Similar Threads | ||||
Soze's GMADE GOM GR01 Build | soze | G-Made Crawlers | 69 | 08-20-2021 12:45 AM |
I want a rock racer. Yeti vs Twin Hammers vs Gom vs Bomber vs Rock Rey | TIME MACHINE | General Crawlers | 27 | 11-20-2018 05:58 AM |
Gom and Wraith at the beach | HumboldtEF | Videos! | 2 | 03-07-2018 03:04 AM |
GOM shifter dust shield. | Ethan503 | G-Made Crawlers | 2 | 01-03-2018 07:18 PM |
Gmade Gom crawling on the backyard course | HumboldtEF | Videos! | 2 | 11-03-2017 09:39 AM |
