12-30-2013, 03:32 PM | #1 |
Newbie Join Date: Feb 2011 Location: Vancouver Island
| transmission noise
hey just got my sawback all together and was messing around with it in the house and I thought that the transmission sounded a little noisier then I thought it should. I've never had a truck with 32 pitch gears so I wasn't sure if that is the cause. I've played around with the gear mesh on the motor, took grease out, put different grease in, its a little quieter now but still way noisier then my SCX 10 |
12-30-2013, 04:55 PM | #2 |
Quarry Creeper Join Date: Oct 2013 Location: Nanaimo
Yup they are. Some have reported that the stock pinion is very noisy(mine wasnt). Robinson racing one will cure that. Also its acceptable to have a little more lash with this pitch as opposed to the stock axial. I would try just snugging the motor mount bolts so you can sill move the motor with the trans out and run it slowly backing the mesh off until it quiets up. Then tighten bolts and reinstall
12-30-2013, 06:03 PM | #3 | |
Newbie Join Date: Nov 2012 Location: Springville
| Re: transmission noise Quote:
Dp you have a link? mine is crazy noisy! | |
12-30-2013, 08:12 PM | #4 |
Quarry Creeper Join Date: Jan 2012 Location: Newmarket, Canada
I switched to an RR 11t, it's a little bit quieter but I don't mind the noise
12-30-2013, 09:13 PM | #5 |
RCC Addict Join Date: Feb 2012 Location: Ca.
Mine was very noisy so I went with a RR 12 tooth. It quieted down quite a bit but as was said, they are going to be noisy because of the 32 pitch. Grease it up well and run it.
transmission noise - Similar Threads | ||||
CR-01 Transmission noise??? | Giznad | Tamiya CR-01 | 8 | 01-17-2011 10:26 AM |
Clicking noise coming from transmission-Help please | promatchrcr | Team Losi Comp Crawler | 13 | 01-20-2010 03:35 PM |
grinding noise from transmission? | pantablo | General Crawlers | 7 | 05-18-2008 12:46 AM |
transmission noise | marlboroman | Axial AX-10 Scorpion | 1 | 02-24-2008 11:59 AM |
transmission noise? | Dickie691986 | Axial AX-10 Scorpion | 3 | 10-31-2007 09:54 PM |
