01-05-2014, 11:14 AM | #1 |
Pebble Pounder Join Date: Sep 2012 Location: Ljubljana, Slovenia
| changing the wheelbase aka The SawbackBlazer
im looking for advice for changing the wheelbase the proline blazer body i have for it is a bit shorter on the wheelbase , i could line up the rear and cut the front or vice versa , this is how it looks at the moment the red lines indicate where i will cut the molder bumper of. one way of doing it i could think of is using square sdi arches to hide the cuts, but am not sure. this is my first leaf based truck so i am not that familiar with them ,any help on this issue is appreciated . Last edited by atf300; 01-21-2014 at 05:55 PM. |
01-05-2014, 12:03 PM | #2 |
Quarry Creeper Join Date: Jan 2012 Location: Newmarket, Canada
| Re: changing the wheelbase ?
You could move the shackle mounts towards the center of the truck to shorten it a bit, you would have to drill new holes in the chassis. Or you could trim a bit of the front or rear fenders out and put some low profile flares on to hide the cut
01-05-2014, 12:20 PM | #3 |
Rock Crawler Join Date: Sep 2012 Location: Roxborough, CO
Kinda like this - just s quick photo edit, so nothing fancy, but to get idea across. |
01-06-2014, 04:09 PM | #4 |
Quarry Creeper Join Date: Jul 2010 Location: Canada
I wonder if you could flip the front hangers around, if you would gain anything. what I mean is put the solid perch on the front and the shackle on the rear of the front axle. that might get you the 5 or 6 mm you need.
01-06-2014, 04:20 PM | #5 |
| Re: changing the wheelbase ? ill try that tomorrow but im not sure it can be done without drilling and cutting.
01-06-2014, 06:51 PM | #6 | |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
| Re: changing the wheelbase ? Quote:
Big Boss Fender Flares for Tamiya Clod Buster Body | |
01-06-2014, 07:18 PM | #7 |
The price is a bit steep on those big boss flares, maybe the sdi squares would be a better option. The flares are an option but I'm not really sure yet
01-06-2014, 08:04 PM | #8 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Use a old windshield wiper blade, the refill type. A Locked up r/c driver did a how to post in one of the next team driver giveaways. HERE Giveaway Week 1: The Next Team Driver - 2 ... win a pile of parts! sgtbham's post Last edited by hotwheels000; 01-06-2014 at 08:18 PM. |
01-09-2014, 02:19 PM | #9 |
today i have moved the front fixed shackle back and drilled a new hole , this is how it looks its better , although the body does not sit level atm since im still mocking up the stealth mount. |
01-14-2014, 12:37 PM | #10 |
Rock Stacker Join Date: Aug 2006 Location: Boone, NC
Looks great. With the body dropped down a tad some 1.5's would look really good. Might cripple it a bit though. I been stalking the sawback forum, as I really think this will be my next purchase. I was torn between this and the SCX platform. I'm really digging all these sawback builds though, and the body you are using is high on my want-list for a scale build.
01-15-2014, 06:59 AM | #11 |
Quarry Creeper Join Date: Oct 2013 Location: Nanaimo
If you really want to change the wheelbase you can build a set of leafs with pullcord spring and drill the axle mount holes slighlty off center to get the desired wheelbase
01-15-2014, 07:01 AM | #12 |
| Re: changing the wheelbase ? |
01-15-2014, 10:28 AM | #13 |
Rock Crawler Join Date: Jul 2011 Location: USA
easier way would just be to move the shackle mounting points, drill a few holes and youre done.
01-15-2014, 10:58 AM | #14 |
| Re: changing the wheelbase ? if you look at my last pic i already did that on the front , it will have to be enough since the frame is not straight and symmetrical and in the rear it starts to curve outwards a bit earlier than on the front .
01-15-2014, 11:20 AM | #15 |
I broke a leaf the other weekend and my lhs cant get parts for the sawback yet so i found myself making some. I built the back ones quite long and moved the rear shackle to the end of the frame and in the front i drilled offset holes extending the wheel base around 7/8" just got to thinking about this thread while i was making them and that this might just be your solution.
01-15-2014, 11:23 AM | #16 |
I think im a modaholic!
01-15-2014, 11:27 AM | #17 |
post some pics ! i need the wheelbase shorter, but i think ill be fine with the moved front shackles. |
01-16-2014, 05:58 PM | #18 |
Pebble Pounder Join Date: Jun 2011 Location: USA
I used TF2 hanger on the front of the rear leafs, moved forward, and reversed the stock hanger at the rear. Shortened the wheelbase to 11 3/8". Sent from my SM-N900V using Tapatalk |
01-16-2014, 07:24 PM | #19 |
Does the rc4wd front hanger fit snug, even though it's bolted to one hole only?
01-16-2014, 08:53 PM | #20 |
changing the wheelbase ? - Similar Threads | ||||
changing the wheelbase of a Axial dingo to the same as the honcho | CUMMINSPOWER617 | Axial SCX-10 | 16 | 11-08-2011 10:25 PM |
changing TQ | duke4you | Newbie General | 2 | 11-05-2008 06:30 AM |
changing username? | stublet | Comments, Suggestions, and Help | 6 | 08-16-2008 07:04 AM |
changing over | jakea | General Crawlers | 4 | 07-11-2007 01:48 PM |
changing your name | Crawler downunder | Comments, Suggestions, and Help | 3 | 06-23-2006 07:52 AM |
