Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > G-Made Sawback
Thread: What are you guys powering your Sawbacks with?
Old 03-17-2014, 09:29 AM   #21
Default Re: What are you guys powering your Sawbacks with?
Tekin RS - PRO ESC and 21.5t Redline S with stock gearing and Power HD 1501MG servo on 2200mah 3s lipo.
rc-pro1 is offline   Reply With Quote
Old 08-19-2014, 11:44 AM   #22
Toro esc
Toro brushless motor 1650kv, 20,5t
Castle Creations bec
Savox 1210 mg
2x 3s 1400 lipo
Skickat från min iPad med Tapatalk
Barba77 is offline   Reply With Quote
Old 10-18-2014, 12:41 PM   #23
You think a 17.5 or 13.5 would run on 3s?
QDRHRSE is offline   Reply With Quote
Old 10-19-2014, 07:22 PM   #24
17.5 should easily!! Just be careful with the throttle finger.
ZippoMan is offline   Reply With Quote
Old 10-22-2014, 10:31 AM   #25
Moderator
JatoTheRipper's Avatar
HobbyKing X-Car 45A ESC - $11
RC4WD 35T motor - $10
Solar D772 servo - $20
Stock gearing
I might change the ESC to the HobbyWing WP-1060 which is a 60A, waterproof ESC. But it's twice the price of the HobbyKing ESC at a "whopping" $20.
Old 10-22-2014, 10:45 AM   #26
Stock gearing
Same, but a 645MG for steering duties. 2200mah 2S
OSRC is offline   Reply With Quote
Old 10-23-2014, 08:42 AM   #27
I run the following
Intergy 55t motor
Castle sidewinder v3 esc
Castle 10amp Bec
Savox 1258tg steering
2200 mah 3s spyder packs
Haven't run it yet trying to work out how to mount mojave body !
Brad_striker is offline   Reply With Quote
Old 11-06-2014, 07:20 PM   #28
Ae2, old peak performance Animal quad16t, 15t pinion, 2s
idaho is offline   Reply With Quote
Old 11-07-2014, 07:41 AM   #29
Tekin FXR rc4wd 45 turn on 3s.
Dialed is offline   Reply With Quote
Old 11-07-2014, 10:42 AM   #30
Integy 55T lathe, Novak Rooster, 15T pinion, Hitec 645MG, 3000NIMH
notarex is offline   Reply With Quote
Old 11-07-2014, 12:32 PM   #31
HH Waterproof BRXL Esc.
HH TorqueMaster Expert 35T with 11T Gmade pinion
Hitec HS7954SH servo / CC BEC @ 7.4v
HH 3S 1300mah lipo
k7zpj is offline   Reply With Quote
Old 01-05-2015, 05:22 PM   #32
Traxxas 2075 steering
Traxxas 5000ma stick pack
Novak sensored-based brushless 21.5T (19tooth)
Now running a Novak Rooster crawler with HH 35T torque master (19tooth)
SuperDutyScaler is offline   Reply With Quote
Old 01-23-2015, 12:04 AM   #33
HPI speed control from my sprint 2
TF40 tx/rx
Integy 35t
genetix_drftr is offline   Reply With Quote
Old 06-30-2016, 02:28 PM   #34
I run a 27t Holmes Torquemaster pro, on 14t pinion on 2s. However it feels like its still undergeard, because its revvin zo high when i just go at just walk speed.
Motor doesnt feel warm. What do you guys advice, do i have te right motor for the job, or should ik go with a lower turn motor on 3s?
WesleyRoy is offline   Reply With Quote
Old 06-30-2016, 04:47 PM   #35
tekin fxr with tekin HD35t motor with a pinion 2 teeth larger than stock....gobs of torque.....smoked all the scx10s in the tractor pull but still loads of low end torque without getting hot....
konasubs is offline   Reply With Quote
Old 07-20-2016, 03:29 PM   #36
Natedog's Avatar
Some good combos here.
That sounds pretty good, if motor is barely warm then go 1 - 2 teeth larger on the pinion and test it again keeping close eye on motor temps.
Old 08-01-2016, 01:35 PM   #37
Dont think this is the right combo for this car, last ride my Sawback just stopped, if i push it then it goes again. Looks like theres something with the motor, changed it for a cheaper 27t expert motor i had laying around, just to make sure i dont ruin my expencsive pro handwound motor.
Old 08-10-2016, 02:37 PM   #38
Natedog's Avatar
Sounds like brushes are worn out, time to turn the comm and install new brushes.
What are you guys powering your Sawbacks with? - Similar Threads
Got our GMADE SawBacks Done! PSCMedia G-Made Sawback 4 11-26-2013 03:54 PM
how are you powering your 7980? tigman250 Electronics 28 01-11-2011 06:53 PM
BR-xl not powering motor slowngreen Electronics 5 08-31-2010 03:06 PM
Powering a Twin BigRedB2 Kyosho Crawlers 12 03-10-2007 04:14 PM
powering a winch SlammedMini469 General Crawlers 5 01-04-2006 02:12 AM
