Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > G-Made Sawback
Thread: Drive shaft ?
Old 06-19-2016, 10:45 PM   #1
Default Drive shaft ?
Who makes the best drive shaft that will fit the sawback ? Part # ?
bill mossor is offline   Reply With Quote
Old 06-20-2016, 01:43 PM   #2
Default Re: Drive shaft ?
I am using THE GPM shafts for scx10, and really like those. Solid, great fitting
Sjonnie82 is offline   Reply With Quote
Old 06-30-2016, 04:14 PM   #3
The harden steel JUNFAC ones from korea are great. very reasonable. Only broke one cva cup in 2 years doing something stupid....
konasubs is offline   Reply With Quote
Old 06-30-2016, 08:02 PM   #4
I've had great luck with Junfac, MIP Spline drives and STRC.
Jeepiac is offline   Reply With Quote
Old 07-06-2016, 01:16 PM   #5
I have these Junfac's on both of my wraiths. The only thing I can complain/share about these is that those little C rings (don't know what they're called) that are supposed to hold the crosspins in, don't.
Edit: By "don't", i mean that the opening on the "C rings" rattle around until the pin can pop out of the opening, allowing the shaft to slide off un-noticed). No pics, hard at work not working!
I've lost shafts on trails but after some quick backtracking found the pieces and was able to repair with no tools at all. It happened to my other wraith over this past camping trip... not fun when you're already a few miles up the mountain trail!
I'll be pulling them and heat shrinking the crosspins in to place with a heavy shrink wrap, hopefully that'll hold. (Better idea? Do share!!!!)
Cheers guys
Dennis76 is offline   Reply With Quote
Drive shaft ? - Similar Threads
best way to join a rwvo drive shaft to the output shaft on the axle TRAV Kyosho Crawlers 12 01-29-2012 07:37 PM
drive shaft Tydl Axial AX-10 Scorpion 0 01-16-2009 02:49 PM
***MIP C-Drive Drive shaft for the AX10...GIVEAWAY*** Rockpiledriver RCP Crawlers 153 07-01-2008 11:18 AM
drive shaft ???'s IronOx Tamiya TLT Crawlers 5 12-30-2005 12:58 AM
