Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > G-Made Sawback
Thread: Chassis mount steering
Old 08-12-2019, 04:18 PM   #1
Default Chassis mount steering
Have Sawback Military (Jeep) I bought a chassis mount steering plate. Has anyone done this mod yet? If so what other parts that I’m going to need that is not in the plate kit. I’ve already put the steering linkage above the knuckle and the drag link is above the spring. That made a nice difference as no bore bashing the tie rod into the rocks first.
jeeptec is offline   Reply With Quote
Old 08-14-2019, 03:43 AM   #2
Default Re: Chassis mount steering
Had mine on from the start..nothing special to fit. Had the crawlster ackerman kit on at first, at least I'm half certain that's what its called without looking it up again, and had trouble, well a little, setting up the steering linkage to stop bumpsteer. I switched to Gmade ackerman set up with "Last build" thread and no problems. Some servos may be a tight fit tho'.
M and M is offline   Reply With Quote
Old 01-03-2020, 06:18 PM   #3
I 3D print is CMS for this sawback all you have to do is bolt in using the bolts from the body mount and all I did was reroute the steering bar through leaf spring so that it did not hit I didn't have to replace any part other than install the chassis mount
Sent from my SM-G975U using Tapatalk
RcPrintzcom is offline   Reply With Quote
Chassis mount steering - Similar Threads
Chassis mount dual servo for steering and winch. jeepgod Axial SCX-10 10 08-22-2012 07:09 PM
scx chassis mount steering servo madazz Axial SCX-10 10 11-09-2011 09:16 PM
chassis mount steering help chinkychink Axial SCX-10 2 11-20-2010 09:01 PM
wreckluse chassis mount steering. madmaxxed 2.2 Scale Rigs 11 09-25-2009 08:06 PM
