06-24-2005, 11:22 AM | #21 | |
Rock Stacker Join Date: Jul 2004 Location: Texas, San Angelo
06-24-2005, 12:33 PM | #22 |
Quarry Creeper Join Date: Jun 2004 Location: Ventura
okay cool
06-27-2005, 05:45 AM | #23 |
Quarry Creeper Join Date: Oct 2004 Location: Cow crap flats
when i built mine i used 1.5 in. allen head bolts (8/32) had to drill out the ends of the inserts, so i could add a nut to keep the ends tight. the allen heads fit in the shaft. used traxxas ends, never stripped one but i have bent a couple.
06-27-2005, 08:13 AM | #24 | |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
06-27-2005, 06:52 PM | #25 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
cut off is a screwed up arrow that has been cut on i believe :?
06-27-2005, 07:07 PM | #26 |
RCC Addict Join Date: Jun 2004 Location: ORegon
screwed up in what way? like too short? or scratched? bent?
06-27-2005, 07:45 PM | #27 |
Newbie Join Date: Jan 2004 Location: Wichita, KS
Cut offs are kind of like carpet remnants in that once the arrows are sized for a customer they may need to be shortened. The cut offs are what's left over. Oh, I found my invoice for my parts. Check out www.bowman.com Not the most exciting site but the prices are pretty good. sorry the link is phucked Last edited by IBCRUSN; 06-30-2005 at 03:50 PM. |
06-28-2005, 12:55 PM | #28 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Guys that use an overdraw fire shorter arrows than bows without an overdraw. Arrows come in a standard length and need to be cut to size for the bow. The part that is cut off is, oddly enough, called the cut-off. ;) |
08-28-2005, 05:08 PM | #29 |
well i was at Walmart today and looked at arrows and inserts. Do they make any arrows that don't have the feathers on the ends? All the ones i seen had them. plus they had metal ones and CF ones.but anyway, i was just wondering that cause i don't want to spend $3 on an arrow and not be able to use the end of it cause those feather things on there( unless you can cut them off- i didn't look that hard)
08-28-2005, 07:57 PM | #30 |
Quarry Creeper Join Date: Apr 2004 Location: Louisiana
I use the CF arrows from WM. The feathers are just glued on. A quick swipe with a razor and you cant tell the difference.
08-28-2005, 11:18 PM | #31 |
Quarry Creeper Join Date: Dec 2004 Location: Tampa, Fl
The fins are glued on and can be easily skinned off with a knife. I buy my arrows and hardware on ebay. Really cheap.
08-28-2005, 11:31 PM | #32 |
ahh ok, thanks for the info guys |
08-31-2005, 03:13 AM | #33 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
Ok, so in simple terms. The arrow is the "tube", the insert is like a slightly smaller tube that has threads so you can turn in your 8-32 rod and ball end. Right?
08-31-2005, 10:46 AM | #34 | |
08-31-2005, 07:45 PM | #35 |
Newbie Join Date: Aug 2005 Location: Martinsburg
Just had a brain fart, since these arrow links are not bullet proof I thought it might be a good idea to be able to reuse the inserts. As you are always improving on your crawler things change, wheel base, chassi, etc. The inserts are hollow but only threaded in the middle not threaded all the way through, working on the same principle as drywall anchors, I split the bottom end of the insert with a dremell cut off disc. Since the inserts are not threaded all the way through the screw bottoms out, I split the insert just at the point where the screw bottoms out. Now I place the insert into the arrow shaft and hold it with a vice so it wont turn and screw down the 8/32 screw forcing the split ends outward and thus keeping the insert from pulling out. You can still pull out the insert by hand but it does take a lot of force. I guess care should be taken on how far you insert the screw or else you could possibly crack the arrow shaft. Be interesting to see if this holds up or not in the long run. What do you think. |
08-31-2005, 07:54 PM | #36 | |
08-31-2005, 08:11 PM | #37 |
Had that picture been posted 6 months ago, I don't think we'd have any threads on arrow links. Good job JIA! |
