| | #1 |
| I wanna be Dave Join Date: Jun 2004 Location: Not where I'd like to live
| Can someone do a quick tech article on how to make them with links to buying parts and some good pics? |
| Sponsored Links | |
| | #2 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| yes please... i got lost on having to have the inserts... I'm not a bow hunter, so have no clue on arrows |
| | #3 |
| Rock Crawler ![]() Join Date: Jan 2004 Location: chicago
| hell yea, i would like to see a tech how to on them as well... |
| | #4 |
| Rock Crawler Join Date: Jun 2004 Location: back in Portland, OR
| Same here! I kind of understand but not too sure. The way I understand it it sounds like they wouldn't be very strong because the inserts could fall out and the sidewall of the arrow is pretty thin. Also are they able to be bent (the aluminum ones) to make high clearance links? |
| | #5 |
| Web Wheeling ![]() Join Date: Jan 2005 Location: Twin Cities
| I made a set for a friends clod and I picked up some smaller arrow shafts for my own links. If you go to a sporting goods store that carrys them, you will find there are several sizes of arrow shafts. Once you find the shaft size you want, then find the size number on the shaft or the package. And then go to the isle with inserts, you should be able to find a packet of inserts with a matching size number. Some inserts are a snug fit and do not need to be glued. Thats how the links worked out for my friends clod, they were all a press fit. Although the links I picked up need to be glued in. I just have not picked up the epoxy for bonding the inserts in place yet. The inserts are all 8-32 tap. And the aluminum is very very stiff. It will snap before it will bend. And you can use a miniture tubing cutter to cut the shafts to size. And you can touch up the ends with a file if you do not like the rough edges. |
| | #6 | |
| 06 Super National Champ ![]() Join Date: Jun 2004 Location: Tennessee
Cliff notes: Get cut-offs from huting shop...they're free! Get inserts to fit your free cut-offs gets some 8-32 all thread Your choice of 1/8 scale ball ends (have to be made for a 4mm link...I use Kyosho's 6.8mm ball ends with Kyosho's "franged" balls) Determine the eye-to-eye length your link needs to be Measure the distance from the center of the ball in your ball end to the butt of the ball end. (If I remember right the measurement on the Kyosho ball ends is 20mm) Add the thickness of your insert's flange. (usually 1mm) That gives you 21mm total. Mulitply by 2....that's 42. Subtract that 42 (or whatever you number comes out to be) from your pre-determined eye-to-eye length. Cut your arrow shaft to that length. Cut the all thread into short lengths. I think I used 30mm pieces. Use adhesive to glue inserts into the shaft. I use BSI's IC2000 I use a drill to thread the sections of 8-32 all thread into the ball ends then thread the other end of the all thread into the insert that's now glued into the shaft. Done. Last edited by JasonInAugusta; 06-22-2005 at 05:22 PM. | |
| | #7 |
| Thats what i thought. Thanks. But is it safe (durability wise) to bend them for high clearance links? (assuming I use aluminum shafts) |
| | #8 |
| I use carbon shafts. They don't bend. ;) As for bending aluminum shafts...I wouldn't do it. |
| | #9 |
| awesome, thats what I was looking for. Good Job Jason. |
| | #10 | |
| Rock Stacker Join Date: Jul 2004 Location: Texas, San Angelo
| | #11 |
| thanks for the info! I never even considered that they were 7075 aluminum versus being 6061. I have a fairly large diameter pipe bender (like 1.5 or 2 inches) so that may be able to bend them safely. I'm afraid it would create a week point though. Well I'll never know unless i try! thanks again! |
| | #12 |
| Rock Crawler Join Date: Dec 2004 Location: Grand Forks, ND
| i might try to check at scheels tomorrow for some cut apart ones for free. lol. how exactly should i ask (some of the guys...most of the guys that work there are d***s) |
| | #13 |
| Newbie Join Date: Jan 2004 Location: Suffolk Co.
| The arrows work great. Strong, light (you could fill the lowers with lead if you were so inclined) and readily available at fair prices. Go the internet route it's far cheaper. Buy whole shafts w/o feathers, it'll make it easier on you and the morons at most chain sports stores. I do find it somewhat interesting that when I first fabbed up a set I was given rash of sh*t about how they are weaker than the 2024 (soft) rod most guys were using. Now whether it's carbon or Al (7075) it's the way to go. Funny how things work out.... Besides the ease of fabricating arrow links one has to consider what the true loads are placed on the links. If I'm not mistaken a 3 link, 4 link etc. suspension system simply locates the axle(s) and has minimal bending loads. If you build the truck/car suspension system correctly the majority of the loads on the links are in tension and compression. Yes, there are some bending loads but RC vehicles don't have the torque and axle wrap that 1:1 vehicles encounter. Well, that's enough. Build a set and tear it up. Cheers, Last edited by IBCRUSN; 06-23-2005 at 04:44 PM. |
| | #14 | |
| Quarry Creeper Join Date: Jun 2004 Location: Ventura
| I have been searching and trying to get info on the arrows so I could use them in my project. Thanks for the info so far but could someone who hunts please explain the sizes I just ran a search and most arrows are available in many sized that make no sense Quote:
| | #15 |
| Yeah Texrock mentioned various sizes, but how does one determine the size for a 8/32" rod or whatever? I wanna try to get in and out of the store before I have to explain WTF i'm trying to do to some dumbass that works there |
| | #16 |
| Newbie Join Date: Sep 2004 Location: denville , new jersey
| awsome info on the arrows i have been dying to do this but also wasnt sure how its pretty clear now though so im doing it. thanks |
| | #17 |
| No matter the size they are all 8-32 threaded inserts. I think the size works with the first two numbers refering to the outter diameter. And the second two digits for the wall thickness. 1816 matches up perfect with revo rod ends. While some of the larger ones are a great match for the kyosho ends. Just go to a local sporting goods store that sells bow hunting gear and look at what they have. |
| | #18 | |
| | #19 |
| so the first 2 numbers are outer diameter in what mm? and second number is wall thickness, also in mm? that doesn't make sense. I realize that all use a 8-32 thread but I just want to know so I can make some kind of a choice, and like Twisted said, I don't want to have to explain to the people working there. Had to do that with trying to find a 23mm socket at home depot, "Why do you need a 23mm? Oh this is for a rc car? how fast does it go, really walking pace, what the hell good is that?" |
| | #20 |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
| The question I have floating around my head is,could a guy tap out the inserts from 8-32 to 10-24? My rod ends won't work with whimpy 8-32 |
| Thread Tools | |
| Display Modes | |
