08-24-2005, 02:43 PM | #21 |
RCC Addict Join Date: May 2005 Location: Auburn, WA
would you quit with the caps.
08-24-2005, 11:51 PM | #22 |
Newbie Join Date: Aug 2005 Location: Safford
Ok I tried the bic pen thing and in about 2 hrs I pulled the treads for my screws out. I ended up machining some new spacers out of aluminum today that are 3/4 inch longer. I left the front and rear shocks. I ended up trimmen the coils on the shocks and borring out the shock bodies for more droop. I know the pics are blurry but I need to buy a new camera. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
08-25-2005, 12:09 AM | #23 |
1970 huh? I like the paint.
08-25-2005, 01:11 AM | #24 | |
Newbie Join Date: Aug 2005 Location: PHOENIX
08-25-2005, 01:19 AM | #25 |
Big man over the internet arent you, I'm not going to highjack the thread and start a pissing match.
08-25-2005, 01:36 AM | #26 |
MY PIC'S....... Last edited by MOB-40; 08-25-2005 at 01:51 AM. |
08-25-2005, 01:39 AM | #27 | |
WELLGOODFORYOUMANI'MBIGINPERSONALSOANYTIMELETMEKNO W | |
08-25-2005, 04:50 AM | #28 |
Rock Stacker Join Date: Aug 2005 Location: vancouver,BC
i've tired doing this but it wont work... im i using the wrong bic pen ?? can sumone send me more detailed pics on how u guys set it up??
08-25-2005, 08:08 AM | #29 |
Quarry Creeper Join Date: Aug 2005 Location: Jefferson City
Hey, Mob...since you reconfigured the rear shocks, do you think that you still need the limiting strap? It seems as though the rear would only drop as far as the shock would allow. I know that hman1991 would need one since he isn't running any shocks, but I wouldn't necessarily think that your setup would require one. I wonder if the same shock configuration would work on the front as well, or if the tires would rub at full lock. I'm very interested in finding this out, as I have something up my sleeve! |
08-25-2005, 09:10 AM | #30 |
Newbie Join Date: Dec 2004
It looks like the scorpion in your pics has a different way oy mounting the linkage to the axle. Or is the blue cap on the axle side just a screw cover?
08-25-2005, 09:29 AM | #31 |
His rear axle still mounts the same...he just extended the shaft out further using a different material. The big difference is in the shock placement. After re-reading what you posted yesterday, Mob, I see why you added the limiting straps. Now, my question is what did you use to attach the limiting strap to the body and axle? I really like the look...it looks very clean. I would love to find out what it is so I can do something similar. |
08-25-2005, 09:47 AM | #32 |
Pebble Pounder Join Date: Aug 2005 Location: lake winola
not all the nylints have the same piviot setup on the axles. my friends was very easy to add the tube to and mine was a pain . his had a screw goin from the back to the middle mine was the oppsite way and made it a bit harder
08-25-2005, 10:40 AM | #33 | |
mine is still all apart. and a pain in the ***. beermonkey do u have the jeep or the scorpion ? im goin to have another run at this set-up when i get home from work. tired doing it all last nite but it juss got abit late. question: w/ the bic pen do u guys use the cap end or do u guys cut it up ?? | |
08-25-2005, 11:35 PM | #34 | |
I FEEL the name of the game is articulation.....hope this help's a little..... | |
08-25-2005, 11:45 PM | #35 | |
and flipped the rear linkage........ good looking out man work's awsome thank'shman1991 | |
08-26-2005, 05:43 AM | #36 |
Pebble Pounder Join Date: Aug 2005 Location: east side - cincy
i tried the pen thing last night and ended up adding like 1/4 - 1/2" onto the wheelbase, so i had to comp. cut the rear body some more. i tried it at first with no shocks, just rubberbands screwed in where they would mount, with the body off the rear would flex all the way to 90 degrees, but after a short test run on it i discovered that not only do i need something to prevent axle wrap, the axle itself would pivot laterally because the only thing holding it at the control arm was weakened and less rigid when i extended it. so it would turn instead of climb when it came to a rock to climb over. so i ended up putting the shocks back on - with no springs. im trying to think of a way to make the rear control arm longer without compromising its strength, i would like a 1" wheelbase extension over stock if i can get it. |
08-26-2005, 12:49 PM | #37 |
| In the rocks with pics
OK finaly got mine in the rocks today. I ended up changing the front and rear shochmounts. I neeed to add limiting straps to the rear, darn shocks bind up about 1/8in from full droop all crossed up. O ya Ill find out tommarow if I need to tear the front axle apart due to gear slipage and poping. If its broke it was a ton of fun while it lasted. |
08-26-2005, 02:10 PM | #38 | |
IT'S BROKE MIND'S THE SAME WAY NEED TO GET A NEW OR FIND THAT CAN BE USED AS A REPLACMENT LOW GEAR..... | |
08-26-2005, 04:44 PM | #39 |
Newbie Join Date: Jun 2004
Ahhhhhhhhhhhhhhhhhhhhhhhhhhh Stop Writing In Caps!!!!! Ahhhhhhhhhhhhhhhhhhhhhhh
08-26-2005, 05:23 PM | #40 | |
