Thread: Zero 3.5 with Bully axles? Anyone running them?
Old 12-24-2008, 05:05 PM   #1
Default Zero 3.5 with Bully axles? Anyone running them?
Looking for the perfect chassis to complement the bully axles that just arrived. Any thoughts? I am looking at DNA and the Zero of course. So far I think the Zero is for me. Does anyone have an input?
thanks fellas
cruciface is offline   Reply With Quote
Old 12-24-2008, 05:08 PM   #2
Everything designed for the bergs as far as the zero chassis and package will work with the bully's.
Kamikaze is offline   Reply With Quote
Old 12-24-2008, 05:14 PM   #3
Good to know, and thanks for the reply. Sure do like those Delrin bent links!
Old 12-24-2008, 05:20 PM   #4
Well everything but the tie rod.
Old 12-24-2008, 05:29 PM   #5
i used the tie rod on the hr moa"s and i only had to cut 1/4 inch off the long side. almost 0 akerman and only 40%on my epa's
BILLYGOAT is offline   Reply With Quote
Old 12-24-2008, 05:32 PM   #6
Thats good to know. Some people are afraid to mod anything though.....
Old 12-24-2008, 06:03 PM   #7
I figured the stock tie rod would not fit. I will only buy the links and the chassis. I have a tie rod that I made that works pretty good. Again, thanks for the great info!
Old 12-25-2008, 03:40 PM   #8
I built my Bullys on a KK4.0 to start. Im currently experimenting with a stick type chassis but the KK steering link is great on my bullys once cut down about an inch. I liked the KK on my bullys but the downside is with the bullys so narrow at the shock/lower link mounts its tough to get it just right on a chassis as narrow as the KK when its stock I put a wider skid in it and it was great. Stock axial skid bolts right in to the holes in the KK plates and its just wide enough. My next chassis experiment will be the Zero-T on the bullys whenever i get around to ordering it.
The notch in the KK steering link made a great servo guard on my setup.
Culetto is offline   Reply With Quote
Old 12-25-2008, 03:54 PM   #9
I mounted the KK delrin bent links on my Zero 3.5 chassis running HR MOA axles and it shortened my rig up quite a bit. Read ALOT.
Is that normal?
RC Shocker is offline   Reply With Quote
Old 12-25-2008, 04:00 PM   #10
WWW.THEROXBOX.COM
I'm running a TAG chassis with my Bully axles it is Alumi and weighs 2oz
The Eye is offline   Reply With Quote
Old 12-25-2008, 07:51 PM   #11
I use some of Special K's products in my Bully build. Check out my thread here: Gemini - A DoubleD Bully
limited77 is offline   Reply With Quote
