Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > General Crawlers
Thread: XTM Crawler
Old 06-02-2009, 10:09 AM   #1
Default XTM Crawler
Got an email and thought I would share.
http://www.hobbypeople.net/gallery/145632.asp
bigdodge88 is offline   Reply With Quote
Old 06-02-2009, 10:14 AM   #2
I have one really had no problems yet will be clocking the axles some time this week to get a little more clearance they get hung up on everything fun to crawl with
kasper is offline   Reply With Quote
Old 06-02-2009, 04:31 PM   #3
thanks for the lead on the crawler I think im going to have to pick one of those up.
brandontodd33 is offline   Reply With Quote
Old 06-03-2009, 06:20 AM   #4
No Problem
Old 06-03-2009, 07:17 AM   #5
Satan is amused...
JeremyH's Avatar
That's not a bad price. Too bad it doesnt meet the Super Class specs....
JeremyH is online now   Reply With Quote
Old 06-03-2009, 09:07 AM   #6
What makes you think that? If your concered about the width of the axles there are ways to set the offset on the stock aluminum rims or go with different rims like Axial's or Maximizers
I have mine all setup using an RCP Hustler chassis and it meets every requirment for the Super Class..
KRAWLR4life is online now   Reply With Quote
Old 06-03-2009, 09:19 AM   #7
Satan is amused...
JeremyH's Avatar
I was referring to the Kit that they advertise as a "Super Class" setup....
"Wheelbase: 15.55" (395mm)"
Old 06-03-2009, 09:59 AM   #8
looks like a great rig but is it comp legal ???
mini max is offline   Reply With Quote
Old 06-03-2009, 10:02 AM   #9
See above. Stock its not, but you can modify it like KRAWLR4life did and you are good to go.
Old 06-03-2009, 10:02 AM   #10
The kit comes pre-built at 15.5" but it's got 3 wb adjustment holes front and rear. I'm at 16.5" right now by just adjusting the mounts and ride height.
John82601 is offline   Reply With Quote
Old 06-03-2009, 10:08 AM   #11
Satan is amused...
JeremyH's Avatar
That, I did not know....
From his description, K4L made it sound like he did quite a bit of custom work to get it comp legal....
Good! Hopefully this will get more folks back to running Supers now that they wont require much custom work. I know that building my super was much more of a challenge than any 2.2 or 1.9 that I have built so far...
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
