08-31-2009, 03:16 PM | #21 |
RCC Addict Join Date: Nov 2007 Location: in the woods
Well, my truck is a pig compared to your feather |
08-31-2009, 03:28 PM | #22 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
So Rob, what do you think after seeing the Eritex rig on the calculator?
08-31-2009, 04:06 PM | #23 |
08-31-2009, 04:10 PM | #24 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Wow it's a lot better than I thought. Correcting for tire size the my bergs COG is .035" higher than Eritex's Losi. Can you weigh a front and rear tire for me? Also, it might be time to get rid of my GIANT bug body.
08-31-2009, 04:20 PM | #25 | |
I'd love something with a very narrow skid and just wide enough for my 3s lipo! It would need to be designed around the pullers though. | |
08-31-2009, 04:29 PM | #26 |
Pebble Pounder Join Date: Jan 2009 Location: omaha
You've been found out Ty........getting tired of my tail lights lately? MOA Losi spanking you getting you all tied up Ty? You can't hide on the boards buddy. Either way they both work better than the Ax, Harley's rig is very impressived and so is Ger's. You still won't beat us! haha, you do really well with what you've got, why change..... |
08-31-2009, 04:36 PM | #27 |
Can one of you please PM me the calculator? Thanks. |
08-31-2009, 04:40 PM | #28 |
Release your anger.. Join Date: Oct 2006 Location: North American Union
08-31-2009, 04:40 PM | #29 |
08-31-2009, 04:49 PM | #30 |
I sent it to you this morning Kenny.
08-31-2009, 05:41 PM | #31 |
Got it Thanks daddy-0! What are you doing when you elevate the front? How? BTW, I'm the feather weight here! 4lb 8.5oz RTR with 3s lipo! I'm working on getting all the data worked up now.....
08-31-2009, 05:50 PM | #32 |
Rock Crawler Join Date: May 2006 Location: Georgia
08-31-2009, 05:57 PM | #33 |
Gold Star Baby! Join Date: Jan 2009 Location: Oroville
That calculator would be a nice item to have...think you can link me? |
08-31-2009, 06:21 PM | #34 |
This is how I did it... Wheelbase - 12.375 Track width - 10.000 Front axle center line - 2.125 Elevated front center line - 8.625 Front weight level - 3.125 Passenger weight level - 3.25 Rear weight level - 3.000 Rear weight Elevated - 3.125 ...that is how I got all my numbers, did I do it correctly? |
08-31-2009, 06:32 PM | #35 |
So does a Losi MOA still have a lower GC than a Berg without clocked axles? One negative of the Losi that I have seen is that the worms prevent the rear from moving at all while front digging. This makes it harder to dig turn on grippy surfaces or when the truck is nose up almost vertical. Insert fuzzy dream sequence here (What if... someone got the gearing right, adjusted the wheels for width, and ran a losi front axle and berg rear??? :?) end fuzzy dream sequence. You'd still have the clearance and turning of the Losi in front, and the berg rear would allow the wheels to turn some while dig turning.... Just a thought... |
08-31-2009, 06:39 PM | #36 |
Oh ya, the scale was zeroed with the AL strip on it. Just in case you were wondering |
08-31-2009, 07:45 PM | #37 |
Newbie Join Date: Jan 2009 Location: Basingstoke UK
| Bully Axles
This is Son of Cobbler. Bully axles,2 Integy 55t motors,Mtronics ESC and 4 cell Lipo. Soon to be fitted are 9/11 pinions and a Punk Dig. |
08-31-2009, 07:47 PM | #38 |
Ahead of axle - 8.6745" Left outside Pass tire - 3.8109" Height from ground - 2.2017" 71% weight up front (Roll over angles) Driver side - 69.6594 degrees Pass side - 59.9832 degrees Climbing - 75.7582 degrees Descending - 58.3761 degrees Looks like I'm not changing to much! |
08-31-2009, 07:50 PM | #39 | |
08-31-2009, 07:58 PM | #40 | |
Looks like the same procedure I use I really want to find a cheap 4 scale setup to really get serious about weight tuning. Quote:
