Thread: Hot racing moa
Old 08-28-2010, 12:02 AM   #1
Default Hot racing moa
i'm not in the market for these axles but i'm wondering why there isnt; a seperate section for them?
Do people not run them? do they fit in the AX10 ection because technically they are a hop-up? and are they any good?
Kraqa is offline   Reply With Quote
Old 08-28-2010, 08:45 AM   #2
There are alot of them out there.
You can find info on them in the Enroute Berg section. The reason being, that the parts are somewhat interchangeable.
With the right additions, they do just fine and are the same width as stock Axial axles.
JC
skid plate is offline   Reply With Quote
Old 08-28-2010, 09:00 AM   #3
TEAM MODERATOR
Reflection's Avatar
Why there's no section? Numbers really. There's a handful of guys running them.
Like mentioned,there is a little tech in the Berg section since some parts interchange. For the most part,all the moderators try to keep any of the Hot Racing MOA builds in the General Crawlers section.
Reflection is offline   Reply With Quote
Old 08-28-2010, 10:48 AM   #4
HR MOA axles take a lot of work to get them indestructable but well worth it.
I run HR's and love them, I use berg 4 gear or (locker) and until my SD 300's
were made (thanks John R) I would machine down berg axles and run them as well which is still in my rears.
I can give you a quick break down on likes and dislikes since I have run them since the begining
1. narrow
2. super light weight
3. better bearing than bergs stock ones
4. tough long lasting gear sets
5. Axial outers bolt right up
6. small footprint where as bully's are bulky
dislikes
1. weak inner axles in stock form
2. not much support on housing parts
from distributors
besides that they are an excellent choice.
Rokpile is offline   Reply With Quote
Old 08-28-2010, 11:16 AM   #5
This post has some good info on the HR's.
Everything HR
I'm currently going thru mine getting it ready for Nats. Re-did my link/shock setup and going for a better electronics layout.
Destroyer is offline   Reply With Quote
Old 08-28-2010, 02:15 PM   #6
Colt Python/SR9c
TwistedCreations's Avatar
99.9% of the reason that they do not have their own section, is because it is not as a "kit" as the other trucks are.
TwistedCreations is offline   Reply With Quote
