Thread: 1:18 help needed
Old 02-26-2006, 03:19 PM   #1
Default 1:18 help needed
hi
i just got my 1:18 jeep rock crawler friday and yesterday while it was charging
i took a pen and cut it and lengthened the wheel base front and rear, I then gave it a bit of a body lift cause the tires were hitting
im wondering how to take off the wheels, if there is a way to widen the width of the wheel base, and how to do a tummy tuck?
TIA
Steve
we3jeepers is offline   Reply With Quote
Old 02-26-2006, 11:23 PM   #2
check the 1/18th nylint forum....TONS of info. Your on jeepaholics.com arnt you?
customxprone1 is offline   Reply With Quote
Old 02-27-2006, 05:21 AM   #3
i was checking and there is a lot of stuff to sift through
oh and ya im on jeepaholics.......that and about 18 other jeep BB's
Old 02-27-2006, 05:31 AM   #4
Cool
Originally Posted by dezfan
Take the center "hub cap" off by twisting it w/ pliers or the Nylint tool. Then just use a regular Phillips screwdriver to remove the bolt.
i thought that was how but i wasnt really sure
i didnt want to blemish the pretty chrome.......
do the 1:6 tires fit the 1:18?
or is that asking for stuff to brake???
oh and it seems that the front tire is held on by a screw and the back is a small bolt
trying to think of a way of widening the width of the wheelbase
i have a few ideas
Last edited by we3jeepers; 02-27-2006 at 05:56 AM. Reason: found something interesting
Old 02-27-2006, 03:44 PM   #5
Try taking the 4 screws out of the back of each wheel and put the back part of the wheel on backwards. Little wider and taller
This is where I found it
running skinny claws
Johnson420 is offline   Reply With Quote
Old 02-27-2006, 03:48 PM   #6
Only the 1/6th includes the tool for removing the caps. I have tried lots of things, and the only thing that made a difference was custom cutting the tires, and removing the springs from the shocks.
rm25x is offline   Reply With Quote
Old 02-27-2006, 04:55 PM   #7
Unhappy
i might need a new tire.....and a finger
i was drilling the center a lil bit and i guess the bit was too sharp
it wasnt really cutting then i pushed and it went through the tire and into my finger
hurt alot and blead a bunch and still sorta does if i squeeze it
i will try the flipping the tire around maybe
BTW anywhere to get new wheels just need the chrome part???
Old 02-27-2006, 05:43 PM   #8
lol, well done wiht the drill i just sliced some skin off my thumb trimming plastic parts :?
Bknight is offline   Reply With Quote
Old 02-27-2006, 07:00 PM   #9
ok well seein as i am now hated here..but ur new and dont know me..depending on how wide u want it u could even go with narrowed 2.2s...umm cutting springs help just removing them helps alot
scorpioncrawler is offline   Reply With Quote
Old 02-28-2006, 11:27 AM   #10
Thumbs up
ok i dont hate ya .....maybe later lol
so what is this 2.2 mod? and how do i do it?
removing the springs ...........maybe might try that out once
we have a hobby shop i might stop in there and see what kind of stuff they have
