Thread: Axle Stall (clod stall)
Old 03-31-2006, 12:56 PM   #1
Default Axle Stall (clod stall)
is there any way to stop my nylint from stalling out
i get in certian positions and ether the front or the back wont spin
i dont even have huge tires on it just stock tlt tires
TheRangerman0 is offline   Reply With Quote
Old 03-31-2006, 02:14 PM   #2
There are a few mods to fix that but even if you use these mods, you will still get into positions where you will stall out like if one tire gets wedged between 2 rocks or stumps it will either slip or stall out.
I took my axles apart and glued the fingers on the gearset with the metal plate to the slots on the opposite gearset and it worked fine for awhile.
TJ_Krawler is offline   Reply With Quote
Old 03-31-2006, 11:23 PM   #3
your better to stall out motor then to strip out the gears.if you want to cut down on the stalling you can do the low low gear mod or maybe increase to voltage by going to a 7 cell pack.
twisted is offline   Reply With Quote
