02-27-2004, 01:07 PM | #61 |
Quarry Creeper Join Date: Jan 2004 Location: Ontario, Canada
| Re: Your Trucks
Sounds good Krod! jugg_crawler |
02-27-2004, 07:00 PM | #62 |
bendforthebone Join Date: Feb 2004 Location: Jamul
| Re: Your Trucks Yea I got it! |
02-27-2004, 07:16 PM | #63 |
Rock Crawler Join Date: Feb 2004 Location: Astoria, Oregon
| Re: Your Trucks
Sorry man, not quite.
03-28-2004, 09:49 AM | #64 |
| Re: Your Trucks
Finally I figured out how to post pics. Here's one of my truck. I have a pair of X-Factor axels and Jumbo Kongs that should be here next week. I am then using a 15.5 in. wheelbase, and T-Maxx-sliders, and a gear reduction unit. I will post pics when it is all done. jugg_crawler |
03-28-2004, 10:44 PM | #65 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Re: Your Trucks
My clod: http://www.rccrawler.com/postp2069.html#2069 thats the buildup, lotsa pics there. No body on it yet, when I get one on there Ill post up a cool 'poser' pic ;)
03-29-2004, 05:53 AM | #66 |
Newbie Join Date: Feb 2004 Location: Ontario, Canada
| Re: Your Trucks
my Twin Force moed the sticks inside the frame upfront with the servo (helps keep the front down (but i can still pop it even with the weight up there lol) running a EVX and Hobbico CS-80 servo (334in-oz @6v) i have it wired so that the exv powers the Rx but the servo pulls its power direct form one of the 6cell sticks (becuze the EVX bec SUCKS) i am colecting parts to switch to 4link going to try Maxx sliders (have), move the servo to the axle, will likly end up droping the evx and x-speeds for a BL setup of some sort waiting on the ball ends to get here then i will go get some threded rod and mock the setup then have the ss links turned action action shot stoped for the pic Joe P.S. im still getting the horazontal rule above the word forums ont eh left pushing the hole post off the right of my screen (1400x1050 my screen size if that matters) if i het refesh it will fix its self but its real anoying |
05-13-2004, 07:53 PM | #67 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| Re: Your Trucks
lets bump this back to the top since we seem to have alot more people joining each day well here is my " Black Widow " project that started out as an Emaxx. turned into straight axles,has a little over 4" of clearance under the diffs,5.75" under the chassis,total height is 12.5", wheelbase is 15.5", axles( outside of tire-outside of tire) are 17.5". i am finally happy with where it's setup and can get 11.5" under one tire with the rest planted to the ground |
05-13-2004, 08:20 PM | #68 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
| Re: Your Trucks
Custom chassis and 4 link clod with Land Cruiser 70 body. My first clod and first attempt at building a chassis. Not too pretty, but works extremely well. Next time I will build a tube frame, if I ever get a welder. |
05-13-2004, 11:06 PM | #69 |
| Re: Your Trucks
This is brians old chassis. I am getting closer to being done, I am awaiting 2 orders. enjoy, |
05-14-2004, 12:11 AM | #70 |
Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
| Re: Your Trucks
you got to mount your stuff up top so the esc and rx dont get splashed with mud and dirt from the wheels. Are you running the widemaxx because thats what i built it on. just would like to know if it fits on the arms well. your almost there just batteries, shocks and steering. |
05-14-2004, 09:19 AM | #71 |
| Re: Your Trucks
I looked at mounting it up top, but I am gunna baby this truck and only take it out when it is dry, so mud and dirt will not be an issue. Plus if you look at the evx mounted in the back (where the rx is ment to go) you will see the triple heatsink I have on it, so I figured it was best to keep that weight down. As for battery I'm thinking about mounting it on the rear axle,grinding down the rear bulks. Think it would be a good idea? I'm trying to keep this trucks Cog down as much as possible. Thanks again for your input.Almost forgot to say, I'm using the old maxx arms, it seems to be working fine.
05-14-2004, 09:28 AM | #72 |
| Re: Your Trucks
Hey Maxxzilla, that looks pretty good! I think I am going to get started on a Maxx crawler as well. jugg_crawler |
05-14-2004, 09:34 AM | #73 |
| Re: Your Trucks
Thanks, but I most of the credit goes to Sky. I am thinking about making a cage for it, we will see. I mean "Pretty good, if you knew how much money I spent on it, you would like it more" (end quote of juggy crawler) Sorry, had to do it
05-14-2004, 10:07 AM | #74 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: Your Trucks
Here is a pic of my stock TXT-1. Rooster ESC 2 HS945MG servos Novak XXL reciever 9 tooth pinion Locked diffs Glued tires I have since made alot of changes. Custom cut tread Chassis modified Custom links from Dirk Mounted the servos on the axels Raised the Tranny up Here is where all my pictures are. http://rc.badgerracing.com/modules.p...view_album.php |
05-14-2004, 11:43 AM | #75 |
| Re: Your Trucks HAHAHA!!!! Thanks Maxxzilla. That was fair. jugg_crawler |
05-14-2004, 12:04 PM | #76 |
| Re: Your Trucks
Here is The Duke 16 Ga steel frame, full roll cage, aluminum links triangulated at the lowers, coils spring supension front and rear, TMaxx shocks with homemade cantilevers, Mag Mayhems, Super Rooster, JB Lockers, 8T Rear 9T front pinions, Ace-built wheel adaptors, Imex Maxx Outlaw wheels, Savage Tyres |
05-14-2004, 12:47 PM | #77 |
Rock Stacker Join Date: Apr 2004
| Re: Your Trucks
Here's my almost stock clod... Scott |
05-14-2004, 04:45 PM | #78 |
| Re: Your Trucks
Po when are you gunna get a new chassis for the clod? An juggy, the balls in your court....
05-14-2004, 06:49 PM | #79 |
| Re: Your Trucks
Very nice chassis, allmost makes me wish I had a clod...
05-14-2004, 10:07 PM | #80 |
| Re: Your Trucks
Looking at it, its going to need a bit more metal... its still an awesome start though!!
