06-10-2011, 01:12 PM | #21 |
06-10-2011, 05:00 PM | #22 |
Rock Crawler Join Date: Jan 2010 Location: SOUTH CRAWLINA
vaseline. |
06-10-2011, 05:12 PM | #23 |
i run sta-plex , its wheel bearing grease $4 a tub, very very close to Lucas red N' tacky. and if you do end up buying the over priced rocksmith jelly just know the teflon bits/flakes in it are not good to run on/ in plastic gears like axial trannys, but a very light coat of just about any regular grease will work well with plastic gears. but i prefur my wheel bearing grease for metal to metal in rc applications as it is ment to resist pound out and last a good while in my Losi with the worm gears. Last edited by 2500hdon37s; 06-10-2011 at 05:15 PM. |
06-10-2011, 05:47 PM | #24 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
I use some wheel bearing grease I got at my dad's work, I think it's Castrol but not entirely sure.
06-10-2011, 06:02 PM | #25 |
Quarry Creeper Join Date: Nov 2010 Location: Athol
Yea, I got Ford wheel bearing grease, thats the stuff that let all the crap in my housings (damn ford products) But has anybody actually tried Automatic transmission fluid? Cause it seems like it would work decent? Most of it would sit at the bottom, and then when the gears start moving, it would drag the fluid from the bottom, up through the gears.. Just my $.02 Seems to make sense to me. |
06-10-2011, 06:04 PM | #26 |
Quarry Creeper Join Date: Apr 2011 Location: United States
I'm thinking thats gonna leak and make a mess
06-11-2011, 06:37 AM | #27 |
When I first assembled my AX-10, years ago, I thought I could seal the case halves with black Permatex RTV and fill the axles with Lucas gear oil stabilizer. I severely underestimated how much the housings flex. They constantly leaked slowly for the next ten hours or so of use. Sure were nice and quiet though. I predict that trans fluid would just make a mess much quicker. I've since refilled them with Lucas Red and Tacky #2 and couldn't be happier. |
06-11-2011, 08:39 AM | #28 |
Valvoline synthetic grease. Huge tub for $10 or so. Use it on my big crawler and little crawlers and bikes and motorcycles and......
06-11-2011, 12:52 PM | #29 | |
Rock Stacker Join Date: Mar 2011 Location: california,Modesto
My transmission was loud as hell to. take it apart put some of this on every bearing inside and BLAM!!! it runs like a champ.. i had a small sip cup i put this lube in put the bearing in it to soak about 5 mins and they work as they are brand spankin new. u can pick this up at home depot for 5$ I also took apart my axles and did those barrings there also Get this right here and put on all your gears, and put some down the axle shafts also, in doing so it will stop the sand before it reaches the bearings. You can pick up this can for about 6-8$ at your local Auto store Last edited by Nitroguy360; 06-11-2011 at 01:03 PM. | |
06-11-2011, 05:06 PM | #30 |
Pebble Pounder Join Date: Jan 2011 Location: Bramwell
where can we get some of that all purpose oil with the zoom spout, it would be appreciated! |
06-22-2011, 10:41 AM | #31 |
Pebble Pounder Join Date: Feb 2008 Location: Bala Cynwyd
I just picked up some Liquid Wrench spray on white lithium grease. The can says it sprays on and sets as grease. I will try it out this weekend and keep you posted |
06-22-2011, 11:47 AM | #32 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
I use Mobil 1 syntetic bearing grease... its red. I have put on all my R/C's including my slash gear box(highspeed) and it stays put, but its not to thick. Found it autozone. I think its about the same as the Lucus stuff. |
06-22-2011, 01:54 PM | #33 |
Another vote for Lucas Red and Tacky #2. Great stuff, I use it in everything from my fullsize yotas, to packing my crawler's gearcases with. For the money I don't think you can get a better grease. Yes, it is thick, yes it does stick to everything very well. No, it doesn't cause enough drag to effect electronics temps or runtime. |
07-01-2011, 01:07 PM | #34 |
Newbie Join Date: Jun 2011 Location: florida
ive found that Bel-ray waterproof grease works great and since its waterproof it keeps water out which is a big plus in my book.
07-01-2011, 03:15 PM | #35 |
RCC Addict Join Date: Oct 2007 Location: gervais
07-01-2011, 03:26 PM | #36 |
Newbie Join Date: Jun 2011 Location: Columbus
sweet! a lube thread! i use KY. jk lol. ive used the cheap marine grease from wallyworld in all my apps. rc's bikes trucks. its waterproof and not drag-ie at all. a lot like vasoline but a thinner viscosity. smells like shit though lol. but works great and is super cheap/ comes ina large tube also so youll have PLENTY |
07-01-2011, 03:26 PM | #37 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Look at my sig, the grease speaks for itself.
07-03-2011, 07:08 PM | #38 |
