08-12-2011, 11:12 AM | #21 | |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
if the bottom was made from metal, it should be work fine one bolt on the bottom as a king pin, most all C hubs use only "one" bolt on the bottom for the steering hub (upper & lower king pins) use a traxxas hub bolt !! good idea | |
08-12-2011, 11:35 AM | #22 | |
I wanna be Dave Join Date: Dec 2008 Location: ?
Yes but that bolt goes the Horizontal and I have broken those. You don't think one hard hit or jump would rip it right out? | |
08-12-2011, 12:15 PM | #23 |
Quarry Creeper Join Date: Jul 2008 Location: lansing
| it is on a slash. im just using the pede arm guards. personally i dont feel as though it would break. i mean you could, anything can be broken. but if it where metal it would just transfer the force to the arm and break the arm instead. if you want i will make you some and you can test it out on your build. just get a hold of me when you start it and i will make them for you. |
08-12-2011, 07:31 PM | #24 | |
RCC Addict Join Date: Oct 2007 Location: gervais
Does the rs4 also just have one screw going through the bottom like that one does in the pic? | |
08-12-2011, 10:31 PM | #25 |
yeah. its just with the rs4 knucles the top and bottom holes are concentric and the 4-tec arms are offset. though come to think about it i dont thing the traxxas ujoints will clear the rs4 knuckle. anywhoo the 4 tec ones work fine.
08-14-2011, 07:19 AM | #26 |
Quarry Creeper Join Date: Jul 2006 Location: pnw
well iwas going to build a ifs rig but got caught up in other things and i bought a crt.5 . it is a 1/8 scale buggy scaled down so every thing is beefy and you can use stander 2.2 wheels . you can get the wheel base aroun9.5 to 10 and up from there. it will be going up for sale so keep your eyes open. |
08-16-2011, 09:39 AM | #27 |
If you do use Slash 4x4 front make sure to up grade to the Alum steering kit. WOW it like a hole new truck
08-16-2011, 04:09 PM | #28 |
08-17-2011, 05:16 AM | #29 |
i will check for ya later today(i have both)
08-21-2011, 12:28 AM | #30 |
4x4 is around 10'' from hex to hex and the axial is like 7.5'' sorry it took so long....totally forgot. Last edited by Gen3_Teg_88; 08-21-2011 at 12:29 AM. Reason: im dumb |
08-21-2011, 12:39 AM | #31 |
That's fine, just means I'll use a wraith axle instead for the rear lol
08-21-2011, 12:43 AM | #32 |
yup. wraith axle would work great. the first thing i said to my co-worker when we got one in was "man. there is going to be a lot of desert truck builds with this axle" it works well with SC/DT.i would but i lack time and money....mostly money, lol.
08-21-2011, 05:25 AM | #33 |
