08-29-2011, 10:48 AM | #1 |
Newbie Join Date: Mar 2011 Location: UK
| Warning for all crawlers..
Hello there fellow crawlers, Im sure all of you already know this, but im going to list it here anyway. DO NOT force your crawlers into a tight turn especially if one of the tyres are caught between two rocks. I have a crawler and I forced it to turn when its front right tyre was caught between two rocks. The wheel knuckles bent (plastic ones) and now I have to replace them. Just a reminder |
08-29-2011, 12:18 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Uumm yep that'll do it. Do yourself a favor and switch to aluminum parts |
08-29-2011, 12:41 PM | #3 |
Wow, what a revelation. |
08-29-2011, 12:43 PM | #4 |
Rock Crawler Join Date: Mar 2010 Location: NRV
1 part high turn motor, 1 part ultra torque servo & you can move mountains... or plastic.... or metal, whichever is easiest to move. I wish there was a little warning light that went off whenever I do this because as much as I know not to... |
08-29-2011, 12:59 PM | #5 |
Quarry Creeper Join Date: Mar 2010 Location: miami
| yeah dont we all wish that lol lol |
08-29-2011, 05:01 PM | #6 |
Lol...or having extenders like 15mm offset on 2.2's with plastic C's and knuckles even on a 12T Titan with not a lot of torque will equate to broken C's in no time! Extenders add a lot of pressure to not only the knuckles and hubs but also to the axle casing itself. Aluminum all the way! |
08-29-2011, 05:45 PM | #7 |
BAH!!! Getting your tire stuck just identified a weak spot in your crawler... If you fix it with the same parts you will know where your weak spot is for next time... If you upgrade your parts you'll get to discover a whole new weak spot.
08-29-2011, 07:02 PM | #8 |
Quarry Creeper Join Date: Dec 2010 Location: Earth
Everybody has done that at least once. To carry on what Greatscott said, your chain is only as strong as your weakest link.
08-29-2011, 07:14 PM | #9 |
Rock Stacker Join Date: Jul 2011 Location: Burleson
Yeah I found my weak spot in my crawler the other night. Sheared my tranny gears in my xr10 so I put the titanium ones in. thumbsup
08-29-2011, 08:39 PM | #10 |
Man i do that all the time, whats the problem?
08-29-2011, 08:52 PM | #11 | |
...that's not the only way to bust a knuckle, its been said: "you have to learn to drive before you learn to crawl". Quote:
08-30-2011, 12:19 AM | #12 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
08-30-2011, 06:41 AM | #13 | |
Best to just leave them on the shelf... | |
08-30-2011, 09:14 PM | #14 |
i need to get myself a pair of aluminium knuckles..
09-01-2011, 11:00 PM | #15 |
RCC Addict Join Date: Jun 2008 Location: In the woods
you will break axles/stubs also.just back up and try again before you do if you wanna keep driving at that moment,comp or not. |
09-02-2011, 10:10 PM | #16 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
A hitec 7980 at 9 volts fixes most issues. I suggest at least one on a 2.2 and a 4 on a super. You will not have to worry about things not moving.
09-02-2011, 11:33 PM | #17 |
Master Rocksmith... Join Date: Jun 2011 Location: Salina
09-03-2011, 12:12 AM | #18 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
Don't even imagine this happening... Or even this Flopped around in there for a while. Thank you Axlemasters. Once you upgrade everything, pick something you like to replace, and make it your weak point. |
09-03-2011, 01:07 AM | #19 |
Newbie Join Date: Aug 2011 Location: Kansas City
| very good advice,last weekend kcrc summer comp watts mill kcmo i was 1 gate away from a clean run course 3,got stuck in a crease,tried to force it out and broke plastic knuckle,after zip tie repair i finished the course w/1 point instead of minus 12,had to use that reverse anyway after "repair"because of loss of steering,and zip ties came off on bonus attempt ending a chance of minus 10 off my score,wish i'd use reverse in the crease to start with |
09-03-2011, 01:49 AM | #20 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
