07-08-2014, 11:28 AM | #721 | |
Rock Crawler Join Date: Jun 2010 Location: KCRC
| Re: Harley's Workshop Build Quote:
20A breaker #12 wire min (#10's if a long distance to panel) 20A rated receptacle (single or duplex) Make this a dedicated circuit (no other receptacles on it) | |
07-08-2014, 01:30 PM | #722 |
| Re: Harley's Workshop Build Which is exactly what I did.... because thats what you told me to do when I did it |
07-08-2014, 02:59 PM | #723 | |
RCC Addict Join Date: Aug 2012 Location: Philippines
Just need to upgrade the breaker and outlet. ...and get the welder. | |
07-08-2014, 03:09 PM | #724 |
RCC Addict Join Date: Nov 2011 Location: cold state
Not to break the bank but starting July 1 most things are to be arc fault protected and the cost went from a 7.00 breaker to a 65.00 breaker. Unless it's in your garage. Then feeder can be Gfci protected. Not saying the outlet will need to be a gfi but the breaker will need to be. First check with local authority when this code change comes into effect in your area first. NEC2014
07-09-2014, 05:37 AM | #725 |
/\......in a commercial application they have been requiring that for a couple years now. (Around my neck of the woods anyway) But we're talking residential here, with no permit, where the home owner is performing the work. |
07-11-2014, 12:30 AM | #726 |
Pebble Pounder Join Date: Jul 2012 Location: Chattown
Harley, where did you find the connector to plug into the welder for the pedal? Sent from my HTC6600LVW using Tapatalk |
07-15-2014, 09:03 AM | #727 | |
I'm not going to pull a permit to replace a breaker and a receptacle... | |
07-15-2014, 09:05 AM | #728 |
| Re: Harley's Workshop Build |
07-15-2014, 09:26 AM | #729 |
I was curious if it's possible to include the amperage control into the pedal mod with this machine as well (obviously it would require more than a momentary switch). toybuilder did that with his and it was a nice feature. TIG Welder Foot Control I really want to get a TIG at home, and like the looks of your machine. |
