01-04-2012, 03:01 PM | #1 |
Quarry Creeper Join Date: Aug 2011 Location: Troy
| Anyone use "Green Grease"?
Just grabbed some of this at the auto store. Its a marine grease called Green Grease. I run through a lot of water so I figured this stuff would be better than Lucas Red and Tacky... Anyways, I havent seen anything on it through my searches, and Im just wondering as to if its safe for plastic or not? Doesn't say on the tube, although it did come in a plastic container... |
01-04-2012, 04:57 PM | #2 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
| Re: Anyone use "Green Grease"?
ive seen it used extensively on quads, dirtbikes, and 1:1 off roaders. never heard anything bad about it. next time i stop in at a parts store that carries it ima get some.
01-04-2012, 05:20 PM | #3 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
People over think the grease thing. Any good grease will work. A nice even layer to lube the parts is what you're looking for.
01-04-2012, 07:33 PM | #4 |
Oh yeah I know. Ive researched the grease thing and have seen some debate Im just making sure it wont eat through my axle casing....and I havent seen too much about it. |
01-04-2012, 08:31 PM | #5 |
Rock Stacker Join Date: Apr 2011 Location: Central, KY
Green Grease is all that I will buy, I use it on trailers, mowers, trucks, jet skis & farm equipment. I guess the only thing that I have not used it on is my RC's. I got hooked on it a few years ago when I have a Polaris RZR. Green Grease repels water like nobody's business. Great product, just a little high @ 7.00 a tube from Autozone.
01-04-2012, 09:25 PM | #6 | |
| Re: Anyone use "Green Grease"? Quote:
01-04-2012, 09:34 PM | #7 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
It's all I use...each time I tear down my axels it's still stuck to my gears...I like that And at $6.95 for a 16 oz tub...I won't run out of it any time soon and I share it with my Crawl mates |
01-04-2012, 11:22 PM | #8 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
i use it in my 1:1 and i love it , thinking about using it in my scaler because of it's water repelant tendencies
01-04-2012, 11:51 PM | #9 |
I wanna be Dave Join Date: May 2006 Location: akron
Its all I use to.. Been going on 2 years of use on R/C's its a good grease..
01-05-2012, 07:37 AM | #10 | |
You found a tub? I was looking all over for one but just ended up with the tube. Im not sure that we've got a grease gun here either | |
01-05-2012, 08:40 AM | #11 | |
I figure I could do at least 100 cars with one tube of grease. | |
01-05-2012, 09:54 AM | #12 |
| Re: Anyone use "Green Grease"? yup...local auto parts store...it was called "marine Grease"...it's a dark shade of green. It's so sticky and waterproof...it's real hard to get of your hands....great stuff
01-05-2012, 11:56 AM | #13 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
i've been using mobil1 synthetic with no issues. I've heard petroleum products can cause plastic to soften. I used generic bearing grease in the trans. for the first year. Never saw any plastic softening. Maybe thats just a myth (softening)
01-05-2012, 07:18 PM | #14 |
RCC Addict Join Date: Dec 2007 Location: Chuck Chuck Chuckin Rocks.
Been using Green Grease for awhile now. Works very good. JC |
01-05-2012, 07:33 PM | #15 |
Quarry Creeper Join Date: Dec 2011 Location: marshall
i used is on my scx10, works great, that truck stayed in the mud & water and i never had a problem with bearings, i did do a little trick though, i drilled 2 1/8'' holes in the housing (one in the top & one in the bottom) and pluged them with real short m3 screws, every time i took it out it the mud after i cleaned it back up i had a Tony Chachere's meat injector ( like a big syringe) that i cut the tip off flat and filled it with the green grease, then i pulled the little screws out and injected grease in the top until clean grease came out the bottom
01-06-2012, 08:20 PM | #16 |
RCC Addict Join Date: Nov 2008 Location: J-Braaaapin It Through Gate 10
Yes marine grease is also all I use but i've been trying out silicone sprays like gun lube and CowRC's Moo-Slick and I love this stuff for gears cvd,s or ect and so far so good. I've noticed that if I keep a layer of silicone spray on the gears in my rigs theres not as much wear |
Anyone use "Green Grease"? - Similar Threads | ||||
Recommendations for "good" axle/gear grease? | LowLock | Team Losi Comp Crawler | 5 | 05-26-2011 11:12 PM |
Flat Iron "Green Dot" | jimjam | Tires and Wheels | 6 | 12-12-2010 12:24 AM |
Awesome new Tuber/AX-10-the "Mean Green" machine! | birdie_in_texas | Axial AX-10 Scorpion | 11 | 07-23-2008 12:28 PM |
project "GREEN MACHINE"mini-giant | Jt | Tamiya TLT Crawlers | 14 | 01-19-2005 02:51 PM |
It's ALIVE, big, bad, and green... "The Hulkster" | Unruely | Tamiya Clod Buster | 5 | 04-20-2004 07:34 PM |
