01-13-2012, 12:01 PM | #1 |
Newbie Join Date: Oct 2010 Location: Manchester
| Need other's opinions
I'm going to make a custom scaler and unfortunately the front and rear can't be the same. I've found setups where the rear would have a 2.92:1 gear ratio and the front would be 2.83:1. In your opinion, are these close enough as to not worry about it, or should I keep looking? Ideally, I want a solid axle with a 2.83:1 ratio, does anyone know of one?
01-14-2012, 09:33 AM | #2 |
| Re: Need other's opinions
You should be just fine. There are plenty of folks out there running overdrive/underdrive gears in their AX10 axles and those are 2.57:1 and 3.31:1 ratios.
01-14-2012, 04:09 PM | #3 |
Okay, thanks for the info. I couldn't see it being a big issue, but wanted to make sure.
01-14-2012, 06:31 PM | #4 |
Newbie Join Date: Oct 2010 Location: frederick
you just want the higher gear in the front to help pull the front up the hills
01-14-2012, 06:35 PM | #5 |
| Re: Need other's opinions |
01-14-2012, 07:02 PM | #6 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
That is so close u could even go more of an overdrive in the front to give u that go climbability! Are u using 2 different manufactures axles? Should b interesting.
Need other's opinions - Similar Threads | ||||
Opinions Please! | truegaintfree | Chit Chat | 17 | 01-10-2008 12:58 PM |
Need opinions! | mudrinner4ever | Chit Chat | 5 | 09-26-2006 04:08 PM |
Need opinions... | All Out Racing | Chit Chat | 13 | 09-06-2006 02:35 AM |
I need some Opinions!! | Sneff | Tamiya Clod Buster | 9 | 08-30-2006 03:18 PM |
