01-19-2012, 01:16 PM | #1 |
| Where to find 32p 20t 5mm gears?
I need 2 steel 32p 20t 5mm bore gears. I've seen a few that are .8 mod, is that the same? Will 2 .8 mod gears work in place of 2 32p gears? |
01-19-2012, 01:35 PM | #2 |
| Re: Where to find 32p 20t 5mm gears?
.8 MOD is close enough that it will mesh with a 32P gear, I've used them to make home made dig units mixing old Tamiya Bruiser trans gears and the shift collars without any issues. Robinson Racing is probably the best place to find gears like this.
01-19-2012, 01:49 PM | #3 |
TRA5646 as BigSki says, it's compatable with 32p. Never used that setup. Found these too. AL though. http://www.castlecreations.com/products/ccpinions.html Last edited by Szczerba; 01-19-2012 at 01:53 PM. |
01-19-2012, 02:26 PM | #4 |
Quarry Creeper Join Date: Nov 2006 Location: Manchester
| Re: Where to find 32p 20t 5mm gears? |
01-19-2012, 05:48 PM | #5 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
| Re: Where to find 32p 20t 5mm gears? Mod 1 & mod.8 are not the same !! just a little different on the tooth angle. try-ed a mod 1 pinion on a traxxas spur gear & they were not happy working together. AMain Hobby has them, & in stock Robinson Racing Extra Hard Steel 5mm Bore .8 Mod Pinion Gear (20T) |
01-19-2012, 05:54 PM | #6 |
I wanna be Dave Join Date: May 2006 Location: akron
Hobbypartz has 19 and 21 if that will help.. Hell of allot cheaper to. and a pretty good gear. 19T Steel Pinion Gear |
01-19-2012, 08:19 PM | #7 |
Sooo, is Mod 1 the same as .8? Or the same as 32p standard? 32p standard measures roughly to be just under .75" I believe. I need 2 gears to fit in place of 32p 20t on a 5mm shaft! In a bad way! |
01-19-2012, 08:33 PM | #8 |
if all that matters is the diameter of the gears and not pitch they are all real close there. it sounds like you are working with a fixed space? not a gear mesh between same pitched gears?
01-19-2012, 08:35 PM | #9 | |
| Re: Where to find 32p 20t 5mm gears? Quote:
Sounds like .8 mod is .70? | |
01-19-2012, 08:54 PM | #10 |
Mod. 1 is 25.4 teeth per inch .8 is 31.75 teeth per inch 32 P is 32 teeth per inch So looking at that mod 1 wont match up with the same tooth count for a fixed space.. this looks pretty reliable to other source's I have found only formated for what we do How to Understand Gearing - Ref. Pg1 - R/C Tech Forums here you go scroll down half way gear calculator all done for you.. http://www.gizmology.net/gears.htm Last edited by sloppy; 01-19-2012 at 09:03 PM. |
01-19-2012, 09:14 PM | #11 | |
I'm thinking that .8 should work! | |
01-19-2012, 09:15 PM | #12 |
Search Noob .8 should work fine.. |
01-19-2012, 09:47 PM | #13 |
Mod .8 and 32p will mesh up, as was said. It will be noisier than a matching gear though. Mod 1 is normally 1/8 gearing. I've had decent luck with rcmonster mod1 and mod.8 pinions 5mm bore .8 mod Super Hard Pinion Gear, Gears/Tranny Parts |
Where to find 32p 20t 5mm gears? - Similar Threads | ||||
32p gears? | devestator_x | HPI Wheely King | 2 | 09-03-2009 09:58 AM |
