02-05-2012, 09:18 AM | #21 |
Rock Crawler Join Date: Sep 2010 Location: Little Rock, AR
| Re: XR10 Axle Shafts in SCX10 Housings? bingo, if you don't add material then take your time and very slowly grind your flats making sure they just BARELY fit in a stock locker and i mean nearly press fit, youll be goo to go |
02-06-2012, 01:50 PM | #22 | |
| Re: XR10 Axle Shafts in SCX10 Housings? Quote:
02-06-2012, 01:58 PM | #23 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
the xr10 bearings on the knuckles are the same as on the ax/scx knuckles. where you run into the problem is where the pivot point is on the two setups, mixing axles and knuckles without the correct C's would screw up that geometry and cause bind.
02-06-2012, 02:16 PM | #24 | |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
Considering all of this, it might be worthwhile to give the RC4WD XVDs a try. I have to be honest, though... With my experiences with RC4WD's drivetrain components, I'm quite skeptical. Hopefully I'll be proven wrong! But if this fails, I'll certainly be considering modding some XR10 axles to be used with XR10 knuckles. | |
03-22-2012, 06:09 PM | #25 | |
Rock Crawler Join Date: Oct 2009 Location: Washington State
03-22-2012, 08:55 PM | #26 |
| Re: XR10 Axle Shafts in SCX10 Housings? |
