04-11-2012, 03:31 PM | #41 | |
| Re: BWD "Project X" Direct Drive Trans...so many applications! Quote:
Especially if you are gonna mount the battery on the other side. I'd still go with teh laydown setup. But stretch the WB a bit to get rid of that crazy driveshaft angle. Last edited by TSK; 04-11-2012 at 03:34 PM. | |
04-11-2012, 03:47 PM | #42 |
RCC Addict Join Date: Nov 2010 Location: England
if the laydown version is more compact, then it would hopefully bring the driveshafts over towards the motor. would be nice to know the dimensions. the direct drive looks a good transmission. a bit like me.. nice and simple Last edited by M1tch; 04-11-2012 at 04:33 PM. |
04-11-2012, 03:58 PM | #43 |
I wanna be Dave Join Date: Jun 2007 Location: Earth
Based on that pic the lay down version would move your driveshafts towards the motor side around an inch, if you factor in placing the lay down (moving motor too) right by the chassis side. Depending your the relation of the top of your skid to the centerline of the axle, the stand up version could also provide significant improvement on your drive line angles. More pics this week will provide much more insight, I promise. Stay tuned! BW Last edited by billet works; 04-11-2012 at 04:06 PM. |
04-11-2012, 04:32 PM | #44 |
thanks. i run a 54T 32p spur gear with 14T pinion. assuming your transmission doesn't have the same amount of reduction as the Axial i would need to change that. the spur is an Associated #2266 just to let you know. lot of people with foff trucks use them.
04-11-2012, 04:57 PM | #45 |
The Project X trans is direct drive and thus offers no internal reduction. That said, a 66/9 32p combo would yield 7.33:1 ratio. In 48p 96/12 48p combo would give you 8:1.
04-11-2012, 07:07 PM | #46 |
Quarry Creeper Join Date: Dec 2009 Location: Nacanowhere Texas
Ok so how much
04-11-2012, 10:05 PM | #47 |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
| Re: BWD "Project X" Direct Drive Trans...so many applications! |
04-11-2012, 10:11 PM | #48 |
Very soon my friends. Lots of updates, pics, and vids should be happening over the next few days.
04-12-2012, 02:34 AM | #49 |
how does the spur mount? also is there a slipper, or possibility of one ?...sudden thoughts as i woke up.
04-24-2012, 05:38 PM | #50 |
Ok so where are the updates and how much are they
04-24-2012, 08:21 PM | #51 |
Master Rocksmith... Join Date: Jun 2011 Location: Salina
04-24-2012, 09:10 PM | #52 |
Just waitin for the go ahead man. I think one of these would be sick in my BWD creation |
06-10-2012, 10:39 AM | #53 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
Sooo....any updates?
06-10-2012, 09:27 PM | #54 |
Here's the direct drive setup I've been working on. Losi Ten-SCTE center diff/motor mount. Scorpion 3800kv out runner. Waiting on a 9 tooth MOD 1 pinion to arrive. With stock ratio r&p, I should have a 12.9:1 final drive ratio. The fastest ratio an Axial trans (with stock r&p) is 15.38:1 so this should have some get up and go. Currently, with a 15t pinion, final drive ratio is 7.8:1 which provides tons of straight line speed, but terrible start up. |
BWD "Project X" Direct Drive Trans...so many applications! - Similar Threads | ||||
project "Punisher" BWD Low Pro | MudboyNJ | Losi Mini-Rock Crawler | 58 | 08-27-2013 12:44 PM |
BWD "Vertex" Micro-Locks on the production BWD "Micro Wedge" | billet works | Losi Micro-Rock Crawler | 162 | 07-18-2010 09:36 PM |
MRC "motor noise" and L-trail chassis "drive shaft" | joeel | Losi Mini-Rock Crawler | 6 | 03-04-2010 04:38 PM |
BWD new "Mini-Locks" - 1.9 "Vertex" | billet works | Tires and Wheels | 21 | 10-26-2009 08:56 AM |
