Thread: Help with spur gear needed!!!!!!!
Old 08-31-2012, 07:23 PM   #1
Question Help with spur gear needed!!!!!!!
I have a custom truggy with a axial trans, and traxxas velinion brushless got it running today and almost immediately stripped the spur gear. I know someone is going to ask and yes the gear mesh was set as near to perfect as u can get. I have a robinson racing pinion and had an axial spur on it. I guess my real question iswhat is thebest 90+ spur gear I can get.
Any help will be greatly appreciatted thanks in advance.
fordsuperduty is offline   Reply With Quote
Old 08-31-2012, 07:36 PM   #2
Default Re: Help with spur gear needed!!!!!!!
Kimbrough.
And you might think about 32pitch, less likely to strip.
Erin is offline   Reply With Quote
Old 08-31-2012, 09:18 PM   #3
Thanks for the helP will look into the 32 pitch stuff I'm shure those will shed dirt and grime better to now to just figure the ratios
Old 08-31-2012, 09:24 PM   #4
Scale Detail Engineering
with the vxl you should definitely run 32p.
I like 5:1 for most of my trucks
You could 6:1 for more torque... when I was running a VXL and Summit trans in a scaler, I was at 7.5:1!
johnnyh66 is offline   Reply With Quote
Old 08-31-2012, 09:55 PM   #5
Definitely run 32p. I switch my Slash to 32p and they last a long time! The Traxxas pinions lasted longer then the Robinson Racing pinions.
SDheavymetal is offline   Reply With Quote
Old 09-01-2012, 05:05 AM   #6
If its an axial transmission the an associated NTC3 spur will fit, and they are made by kimbrough.
#2264 50 tooth
#2265 52 tooth
#2266 54 tooth
they are about the same diameter as an axial 87 tooth 48dp spur
M1tch is offline   Reply With Quote
Old 09-01-2012, 09:20 AM   #7
Proverbial threadkiller
Trubble's Avatar
Originally Posted by fordsuperduty View Post
I have a custom truggy with a axial trans,............ I guess my real question iswhat is thebest 90+ spur gear I can get.
I would suppose it would depend heavily on if you're talking a Truggy, (such as an RC8Te, or a Hyper Mini STe)...... or a Tuber, (such as an SCX based custom build). The difference in gearing between the two is drastically different.
Hints like Axial trans, and 90+ tooth spur lead me to believe it's a tuber. So under that assumption,
I'd hazard a guess that jumping from 48 pitch to 32 pitch you'd just divide your 90+ by 48 and multiply that by 32. So..
90t-48p=60t-32p,
92t-48p=61.334t-32p, ( I always round spurs up, pinions down), so 62t
94t-48p=62.667t-32p, (or 63t)
The tooth profiles on 32 pitch is going to be quite a bit taller than the 48 pitch, so if you match the ODs of the two, your 'datum diameters' will be off. Most will say "not by much", depends then on how heavy your rig is, and how close you are now on your gearing. If you're nowhere near 160°-180° for motor temps, you can safely move a couple teeth. But if you're routinely getting into the 'danger zone' on heat, I'd rather see you do the math and not burn out your equipment.
Trubble is offline   Reply With Quote
Old 09-01-2012, 12:59 PM   #8
thanks guys ive been looking at atleast 63t and around a 9 tooth pinion
im with you Trubble i want to keep the temps down since ive already burnt up 1 speed controller already
Old 09-01-2012, 03:07 PM   #9
The kimbrough spurs are trash, weaker than the stock spur. The plastic is too soft, first bind and all the teeth fold over flat. The Robinson white delrin spurs are pure beef, I've never stripped a 48 pitch one.
indiana mudcat is offline   Reply With Quote
Help with spur gear needed!!!!!!! - Similar Threads
Which spur gear and pinion gear with 35t motor vegas1973 General Crawlers 1 08-19-2012 11:42 AM
Micro T spur and Micro Crawler spur gear. Same thing? matts175 Losi Micro-Rock Crawler 4 10-15-2011 01:18 AM
spur gear dickster Team Losi Comp Crawler 11 11-23-2009 09:42 PM
Spur gear cover needed! TrailDawg362 Axial SCX-10 5 07-25-2009 05:12 PM
Wobbling spur gear....Need alum. gear hub! sickfab HPI Wheely King 26 10-01-2007 02:09 AM
