Thread: Stripped Grub Screw
Old 01-22-2013, 07:06 PM   #1
Default Stripped Grub Screw
Accidentally stripped a grub screw on my drive shaft and cant figure out how to get it out. Any ideas?
Thanks in advance,
Kenneth
jeepscx10 is offline   Reply With Quote
Old 01-22-2013, 07:12 PM   #2
Default Re: Stripped Grub Screw
That's a bummer. Ive always had great luck using a torx bit in place of the hex driver to get out stripped ones. It will depend on how badly its stripped too. Depending on the size of the grub try a t10or t15 bit....
--Dan
sickcivic95 is offline   Reply With Quote
Old 01-22-2013, 07:15 PM   #3
Time for a drill.
Meatwad is offline   Reply With Quote
Old 01-22-2013, 07:27 PM   #4
Metal drive shaft?
First try a pen torch. Heat the surrounding material and then do what sickcivic95 advised you to do. The heat will also burn away any remaining threadlock and it will come out easily.
4wd4ws is offline   Reply With Quote
Old 01-22-2013, 07:38 PM   #5
Cool. Thanks for the help. Dont think i have any of those bits so i guess i will make a trip to the hardware store tomorrow.
Old 01-22-2013, 07:54 PM   #6
Depending on what you have for "meat" left of the screw you can take a flathead precision screwdriver and a hammer and put a slit across the top and back it out that way or a dremel and do the same thing with a cutoff wheel
Phins Fan is offline   Reply With Quote
Old 01-23-2013, 09:31 AM   #7
SuperShafty.com
i used a small drill bit then hammered in a larger hex and it backed right out.
mjderstine is offline   Reply With Quote
Stripped Grub Screw - Similar Threads
diff grub screw? crazee horse Axial Wraith 4 01-26-2012 03:24 PM
Stripped Hex Screw - Craftsman Screw Extractor bigstu Tools, and Procedures 8 11-05-2011 08:48 AM
Stripped grub screw Highboost73 Axial SCX-10 3 09-15-2010 03:48 PM
Grub screw issues ky_18b General Crawlers 11 11-28-2007 07:12 AM
Grub Screw RCCalifornia Chit Chat 4 09-16-2007 04:06 PM
