03-12-2013, 11:16 PM | #1 |
Rock Stacker Join Date: Jan 2013 Location: El Cajon
| My scx10 tuber
So here is my scx10 tuber it's top heavy and the rear shocks (from a tmax) are quite stiff I need advise and help!!! |
03-12-2013, 11:18 PM | #2 |
| Re: My scx10 tuber
I think I want to lower it but am not sure how to do so efficiently.
03-13-2013, 08:05 AM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
| Re: My scx10 tuber
It needs to come down a lot! I'd mount the shocks higher and mount shorter shocks. Try some scx10 shocks. I bet that thing flops over just looking at rocks.
03-13-2013, 10:46 AM | #4 |
| Re: My scx10 tuber
I have my old scx10 shocks... But I need to create a place that is higher in the truck to mount my shocks. I'm not sure if tac welding a little piece of sheet metal on would work or not.... It may not because of the shocks thoughts on how to do it?
03-14-2013, 10:55 AM | #5 |
Rock Stacker Join Date: Mar 2013 Location: Newmarket
| Re: My scx10 tuber
You definately need to mount the shocks much higher in the chasis. I would strongly suggest agains't running shorter shocks as the more wheel travel you have the better. Depending on the thickness of the sheet metal you could use it fine. You could make a u shapped tube and mount it on the upper tube. Tack the sheet metal on the inside of that new tube/chassis with holes in it for adjustable positions.
03-15-2013, 10:21 PM | #6 |
| Re: My scx10 tuber
Would I need a spacer between the shock and sheet metal?
03-17-2013, 09:42 AM | #7 |
| Re: My scx10 tuber
Yes you would need a spacer to clear the shock body. For reference you are trying to make something like this BGR Fabrications Wraith rear shock tower |
03-28-2013, 07:54 AM | #8 |
Rock Crawler Join Date: Oct 2011 Location: Warren
| Re: My scx10 tuber
As said before I recommend getting the ride height lowered. I also noticed that your rear shocks are leaned toward the back of your rig. This has never worked for me on any of my builds. If anything I think that you want them to be tipped forward a bit. A ride height of 2.5 to 3 in at the bottom of the skid is plenty. It will really lower your center of gravity.
03-28-2013, 10:49 AM | #9 |
| Re: My scx10 tuber
Hope this helps.The shocks leaning towards the rear will bind, causing no travel at all. They should be vertical or laid forward a bit. The further they are laid forward the softer they feel on the truck. Def lower the truck, as said earlier, less travel is not a problem so shorter shocks will work. One of the threads on the subject. Too much articulation wtf?!!?!? In my experiance tacking sheet metal to solid rod is very difficult but can be done. Obviously the thicker sheet metal the easier it is. Just looking at the chassis my gut tells me the top of the shockk should be near the middle tube(rod) in the rear and near the top of the hood for the front. |
03-28-2013, 11:17 AM | #10 |
Rock Stacker Join Date: Feb 2013 Location: Arizona
| Re: My scx10 tuber
Can you tilt them inwards toward the center of the chassis with new mounts? The more you tilt them, you also reduce the spring rate effect making them softer because they are not resisting the force 100 % vertically. After remounting them, you could also try softer springs.
07-11-2013, 12:06 AM | #11 |
Rock Stacker Join Date: Jul 2013 Location: dixon
| Re: My scx10 tuber
you could try making a couple of half moon shock hoops and just braise them on the frame that way you still have the travel on the shocks
My scx10 tuber - Similar Threads | ||||
My first try at a SCX10 Tuber | rgf27 | Axial SCX-10 | 36 | 05-12-2012 07:01 AM |
Wraith tuber on SCX10 chassis | tciappa | Axial SCX-10 | 5 | 04-26-2012 08:01 AM |
Proline tuber system on an scx10? | mycrors7 | General Crawlers | 14 | 04-24-2012 05:23 PM |
