03-10-2012, 11:00 PM | #1 |
Pebble Pounder Join Date: Aug 2011 Location: Gresham, OR
| Too much articulation wtf?!!?!?
I've been reading a lot of people commenting on setups that have "too much flex", but not one person has given any useful information that points to the negative impacts of too much flex. Enlighten me. |
03-10-2012, 11:23 PM | #2 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: Too much articulation wtf?!!?!?
Enlighten yourself, not trying to sound rude but just try searching. There are numerous threads on this exact subject, some short, some long but all offer any and all info you could want |
03-10-2012, 11:28 PM | #3 |
Searching helps Too much articulation can get you into a situation that a rig with too much articulation can't get out of. Typically crevices, verts and some undercut situations. A good rule of thumb is a standing tire height of articulation, anything more is an '05 poser pic. |
03-10-2012, 11:45 PM | #4 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
the moment your rig stops articulating it starts pushing the tire down into the rock giving u traction. A crawler with too much flex just flops around on the rocks.
03-11-2012, 12:50 AM | #5 |
Quarry Creeper Join Date: Feb 2012 Location: SAN DIEGO
| Re: Too much articulation wtf?!!?!? |
03-11-2012, 06:56 AM | #6 |
03-11-2012, 07:01 AM | #7 | |
| Re: Too much articulation wtf?!!?!? Quote:
And anything more than a tire height is poser, really... | |
03-11-2012, 07:07 AM | #8 | |
The more articulation you have the more time tires spend on a traction surface. | |
03-11-2012, 07:16 AM | #9 |
RCC Addict Join Date: Mar 2010 Location: RC Addict Garage
Well I have found the generally lots if articulation leads to chassis twist actually lifting a wheel. Also a tire will flop on its side and not be able get back up right easily. I suppose this is all on your driving style. I find I do much better with less articulation. Sent using Tapatalk on my Sprint Evo |
03-11-2012, 07:24 AM | #10 | |
As for a tire flopping on it's side, I can understand that if an axle flexes 90 degrees and can't right itself that it can be too much flex. But what I have been reading on the forum is that anything more than a tire or tire and a half height is for trying to impress chicks. I'm not buying it... | |
03-11-2012, 07:33 AM | #11 |
Rock Crawler Join Date: Mar 2009 Location: Alvin,Texas
Well I guess you know it all then , your good to go. there's a reason everybody went from rigs with 90 degree articulation to limited suspension setup's. Do a search on the subject , it's been covered many times , by People that have been through the evolution of the crawler. Plus that search will get you a lot farther than being a dick around here. |
03-11-2012, 07:42 AM | #12 | |
03-11-2012, 08:00 AM | #13 |
RCC Addict Join Date: Feb 2011 Location: York
If you have articulation with no weight on the cantact patch, you just have a nice picture or an RTI whore as we used to say in the 1:1 world. Let's look at it in a different situation. You're hanging by your ankles on a raised track in your basement. You need to use your fingers to "walk" your way across the floor. If all you have is your fingertips, then you want as much pressure on them as possible. If the track is a little too high, you're fingers will barely even reach the floor...you will have no finger traction to pull you across the room. Lower the track two inches and suddenly you have more pressure and more grip. On a crawler, you can let the suspension stretch all you like, but if it's just barely touching the rock or the ground, it doesn't improve your situation (moving forward off the obstacle). On the other side of the coin, you can drop the wheel into a spot between 2 rocks...if that wheel has no traction to pull you back up and the attitude of the chassis doesn't change, that wheel will stay hung low and literally snag the truck. Back in the day all the guys running leaf springs went bananas over the Terraflex Revolver shackles. These were amazing on an RTI ramp and suddenly the lowly YJ had some respect ;) Until folks hit the rocks and realized the articulation without downforce on the contact patch was useless. RJ |
03-11-2012, 08:05 AM | #14 |
A GREAT setup to combat the lack of pressure was Soni Honnegor's Scorpion MK1. :: A Look Back, A Few Of My Favorite Rock Rigs Of All Time He used an air system to force the wheel down. Last edited by tozrovr; 03-11-2012 at 08:08 AM. |
03-11-2012, 08:10 AM | #15 |
Quarry Creeper Join Date: Oct 2011 Location: Waterford
I just started experimenting with articulation I used to think I wanted the most possible. I have recently found that not only do you get more traction from the action of pushing the weight that was lifted on the opposite side to the tire down hill from it but it also makes your rig predictable. I'll explain.... With too much articulation the c.o.g. Changes on you at different angles causing more rolling. Also when trying to go over gaps you are more likely to get sucked in from the excessive movement in the suspension which we all know is a point and time burner. Honestly the best thing for you to do is buy fuel tube. Set your rig for the most articulation you can run it a bit the put the fuel tube on your shocks maybe only eighth inch at a time and run with different limiters until you like it. I personally like a lot of articulation in the front and bit less on the rear. Sent from my over compensating smart phone. |
03-11-2012, 09:47 AM | #16 | |
but if you dont believe us, go try it for your self... that simple, just remember that you can have too little or too much. | |
03-11-2012, 10:01 AM | #17 | |
Just because all four tires arent touching the ground, doesnt mean you have no traction. You actually have more "grip" in many cases because you have more psi pushing down on the rocks. Limited flex is crucial to any technical crawling. It's easy to float a tire over a big hole. Rather than ask people to enlighten you and then arguing for your entertainment, why don't you get off the computer and get some real world experience. If you like 90* of flex then run it. I sure as shit won't. | |
03-11-2012, 10:11 AM | #18 | |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
03-11-2012, 10:22 AM | #19 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
It boils down to contact patch. The more rubber on the rocks, the better off you'll be. You don't want to be "floating" on the rocks, which is what too much articulation will provide you. --- I am here: http://tapatalk.com/map.php?11d3ce |
03-11-2012, 12:01 PM | #20 |
I'm just happy you are all starting to offer some real examples instead of just telling him to look it up. This is what the op asked for in the first place. Now he has some base reasons to not go too big and has the choice to make. You are all awesome and smart and helpful when your not too busy being dicks Like I said in the other thread last night. I am amazed when I watch you guys conquer obstacles I could not even approach. Us noobies all seem to get stuck on the articulation thing for some reason. Obviously experience has changed the thought process and we are just stubborn. This thread has now become the most helpful Yet! This forum and it's members is such a fantastic resource. Thank you all. |
Too much articulation wtf?!!?!? - Similar Threads | ||||
wtf losi micro with dig and 4ws wtf | richardgarrett56 | Losi Micro-Rock Crawler | 15 | 07-21-2010 04:47 AM |
how much articulation | Losi man | Losi Mini-Rock Crawler | 23 | 11-15-2009 01:54 PM |
Wtf Wtf Wtf Lathe?!?!?! | Nova | Electronics | 2 | 08-19-2005 08:31 PM |
