05-11-2013, 05:41 AM | #1 |
Quarry Creeper Join Date: May 2009 Location: India
| RC Crawler Differential Survey
Hi, I have been busy for couple of days designing a 2.2 axle and differential system for my 2.2 crawler. I was thinking of designing a diff lock unlock system in it and would like to here from people their experience with such a system. 1] What kind of diff lock unlock would you prefer like manually actuated or electronically actuated. 2] What problems have you faced with such kind of diff systems? 3] Would it be a Go or No go to have a diff lock unlock system in your crawler ? Looking forward to hear it all |
05-11-2013, 07:36 AM | #2 |
| Re: RC Crawler Differential Survey
Here is a link to a diff design similar to Venom that I modeled and was studying. Still working on my own design but need some inputs from you guys... 2.2 Crawler Differential - YouTube |
05-11-2013, 07:50 PM | #3 |
looking at the number of replies I guess diff lock unlock system is not present in most of the rc crawler axles out there |
05-11-2013, 07:57 PM | #4 | |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
| Re: RC Crawler Differential Survey Quote:
05-11-2013, 08:00 PM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Casper
It could be useful but I would worry about how strong it would be. I've broken a couple dig units that were not the greatest quality or design. If you can build a bomb-proof one, that would be awesome! And switching could probably be setup in such a way that you could do it manually or with a servo. |
05-12-2013, 12:53 AM | #6 |
Pebble Pounder Join Date: Apr 2013 Location: in a house
Cool project. Been thinking about the same thing. More from an engineering perspective than because its necessary. I have a redcat Rs10XT. Its a 1/10 scale 2.2 MOA with rear steer and locked axles. Strangely there is a diff kit available for it so I got one just for fun. It's a traditional design with sun and planet gears. You can install a kit on both axles if you want since they are identical. There is no lock out. No instructions so I had to use a diagram I found from another redcat model to figure out how it goes together. Might install it tomorrow. I haven't figured out how to lock both the left and the right axles to the the diff carrier/spur. Seems like I need a clutch type arrangement on both sides. I don't do comps but my guess is that having a manual diff would be useful for some courses and probably an settable adjustable slip with lockout would be best since you don't wan the extra weight and complexity. You would set it up for the course appropriately. For bashing or trail I think on the fly would be better and probably the limited slip would be too subtle to really make much difference although if you have it, then manually adjusting the slip seems reasonable. You would need a servo to control it but the servo should turn a worm gear or a cam and not be relied on to hold the diff locked/unlocked itself. Last edited by AutoCrawler; 05-12-2013 at 12:56 AM. |
05-12-2013, 05:59 AM | #7 | |||
Thanks a lot for your input ROCKEDUP RICKY. Quote:
Thanks a lot for your input KJ10 Quote:
A friend of mine has a RedCat Rs10XT and is a fun crawler. If you can, then please upload here some pics of the diff kit before you install it. I can put in my suggestions for it. Thanks a lot for your input AutoCrawler. | |||
05-12-2013, 07:27 AM | #8 |
Pebble Pounder Join Date: Jun 2012 Location: las cruces
What scale is this made for your talking about a lot of options in a small axle
05-12-2013, 08:13 AM | #9 |
| Re: RC Crawler Differential Survey I will be making it for the 2.2 crawlers. I know they all seem to be a lot of options in a small axle, but I know I can design it. I have a lot of ideas in my mind and I am working on their design concept and development.
05-12-2013, 03:03 PM | #10 |
WoF.....sounds like a great idea, I'm sure others will be waiting for your thoughts/ideas. I will say.....sounds like a "fishing thread" which will likely get locked down since you're not a vendor here. Not my concern, nor my rules. I say this since I made an "off hand" comment about a part I had made for a local club member and had a few "moderator PM's" stating the same thing. Not saying you should do different, just saying to expect a pm or 2 soon. As to your question, most lock/unlock diffs I've seen thus far have been disabled since they are either: Fussy & don't work all the time Weak and tend to break My son ran a Venom Creeper, among the 1st things he did (based on info here) was to disable the locking feature so it was always locked. |
05-12-2013, 10:52 PM | #11 | |
On the other hand calling it a fishing thread is pretty harsh. regarding the differential guideline you provided, I am very Thankful to you | |
05-13-2013, 12:28 AM | #12 |
The one type I'd really enjoy is the automatic unlock used on the rear axle of Volvo 903 (late '50ies design). Normally locked, but if the wheels tried to run at different speeds (as when turning) it would unlock and stay so until both wheels ran at the same speed again. |
05-13-2013, 12:52 AM | #13 | |
In case you used the same diff in an rc crawler then it will not work while climbing rocks It will be good if you are speeding on a flat surface and of course it will be good for 1:1 scale too. | |
05-13-2013, 01:15 AM | #14 | |
And I looked it up on u choob and it turns out that's one of the common ways its done in the real world. Give myself a gold star and put me at the top of the class I took some pictures of the Redcat "open diff" but I didn't get around to installing it today. I may get around to posting them up this week. In the mean time it's very similar to this arrangement for a 1/8th scale differential. http://redcatracingparts.net/image/c...3-900x900.jpeg except it is driven by a spur gear rather than a ring gear and spur gear connects directly to the diff housing without the additional plates. Also it's not "hardened" and is smaller. The gears and pins are metal but the diff housing is plastic and the gears are cast not cut. | |
05-13-2013, 07:47 AM | #15 | |
As soon as a wheel slips the lock is engaged. (To disengage the lock some external force must try to make one, but not both, wheels run faster than powered by the drive shaft.) Last edited by Olle P; 05-13-2013 at 07:49 AM. | |
05-14-2013, 01:27 AM | #16 | ||
First you had said that the wheels would unlock if both wheels try to run at different speeds which is somewhat like a limited slip differential. Then in second post you said ...As a wheel slips the lock is engaged. Can you please clearly explain. | ||
05-14-2013, 01:58 AM | #17 | |
Yes the differential concept is same every where except the size, forces and other parameters change and hence some extra components increase or decrease where ever necessary. I had worked for American Axle earlier. Not in the core R&D but I was working for a company that manufactured diff components for them. I remember setting up process to machine the inside sphere of the differential carrier and that job had to be very precise. | |
05-14-2013, 07:22 AM | #18 |
| Re: RC Crawler Differential Survey I think the last sentence I wrote says it all: To disengage the lock some external force must try to make one, but not both, wheels run faster than powered by the drive shaft. A driven wheel that slips doesn't try to outrun the driving axle, it just puts up less resistance. The ground friction of the outer wheel in a turn does try to make it run faster than the inner wheel and driving axle. The external force added causes the lock to disengage, and as soon as both wheels spin at the same speed again the lock is reengaged. |
05-16-2013, 02:00 AM | #19 | |
The problem with locking the diff is deciding when to unlock it. Since the wheels are locked together there will never be a difference in speed between those wheels to trigger the unlock. Generally practical modern real world systems unlock when the whole vehicle reaches a certain speed. This is largely a safety measure since a locked diff at speed will cause the vehicle to roll in a turn - avoiding this was why differentials were invented in the first place. The solution to this is to use a limited slip differential. These act like they are locked until a large enough difference in traction between the wheels and the limited slip mechanism enables the differential to act thus allowing the wheels to turn at different speeds. When the traction difference is no longer sufficient then the wheels again act like they are locked. The limited slip diff is never really fully locked since it's not as binary as my simplified description implies. Perhaps this is what you mean? | |
05-16-2013, 02:47 AM | #20 | |
With an open diff if a wheel slips more power is transfered to that wheel, making it spin faster. No additional external force is involved! This diff is locked by default, so if a wheel slips more power is transfered to the wheel that has grip, and both wheels keep spinning at the same speed. To unlock it an external force must add speed to one wheel only. (Reduced traction doesn't force a wheel to spin!) What's good about it is that when there's grip it behaves as if open, but when the grip is lost on one or both wheels it stays locked. | |
RC Crawler Differential Survey - Similar Threads | ||||
Survey - would you consider buying a US$130 rock crawler? | wildthing | General Crawlers | 23 | 05-22-2013 09:16 AM |
Got some time? Want to help with a survey? | JohnRobHolmes | Chit Chat | 5 | 02-22-2009 09:40 AM |
college english class RC crawler survey | Del Montess | Chit Chat | 44 | 01-17-2009 11:51 PM |
2.2 Crawler Wheelbase / Width Survey | ARC MotorSports | Tamiya TLT Crawlers | 16 | 05-13-2005 11:33 AM |
