03-14-2014, 06:52 PM | #1 |
Pebble Pounder Join Date: Aug 2005 Location: lake winola
| tranmission/axle choices
So i bought a cool tube frame buggy chassis for cheap and want to build up something that i can really hammer on and not break to much, kinda like rock bouncing stuff. i had planned on just using whatever kind of tranny i find used and replace parts as i break them but now im wondering if i should just get the rc4wd R2 HD tranny, does this hold up good to big brushless power? Also need to decided on axles, i can get a set of g-made R1 axles that need some parts for $35 so i had planned on getting them and a set of ebay straight axle conversions for them ( i dont want gear reduction, not really making a crawler) What do you guys think abouy this? |
03-15-2014, 07:02 PM | #2 |
Quarry Creeper Join Date: Nov 2013 Location: Huntsville
| Re: tranmission/axle choices
I have not been impressed with my RC4WD R2D transmission. The dig sticks badly and I've already worn out the final drive gear and that is with a brushed motor. To be fair, though, it may not have been properly lubed to begin with. I've since lubed it and it is holding up. Perhaps the HD will hold up better. I'm replacing with an Axial Wraith/SCX10 transmission that will be rebuilt with Vanquish, Integy, and RPP components. As for the Gmade portal axles, I love them. They have held up well under the abuse that I've dished out. But I would not recommend them for a higher speed bouncer.
03-16-2014, 05:47 AM | #3 |
well i went and ordered the R2 HD , i still plan on buying the axles since there cheap, im sure they go in something. i think ill look for some wraith axles for this build up.
03-18-2014, 04:25 PM | #4 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
i would definatly stay away from the r2 trans. it wont hold up long with brushless power. |
03-18-2014, 09:41 PM | #5 |
Quarry Creeper Join Date: Sep 2013 Location: post falls
I'm running a roc412 on 3s through a built scx10 trans with zero issues in a rig that's not light, super light buggy+r2 trans+weak hobbywing setup on small 2s=epic trans failure and the roc412 get driven much much harder, I wouldn't use an r2 trans for big brushless power.
03-19-2014, 02:22 PM | #6 |
Quarry Creeper Join Date: Apr 2012 Location: lake wylie
Just my $.02. I would use an axial trans and ar60 axles with hd gears. Or if you happen to have a xl5/vxl traxxas 2wd trans handy they will take massive power stock but they are bulky. Just lock the diff, mount it sideways and connect the driveshafts to your axles.
03-20-2014, 05:50 AM | #7 |
welll that sucks cause i ordered the R2 heavy duty version, says right on the page its for big motors, well maybe ill put it in my scale scx10 and build up the tranny in that for the buggy
03-20-2014, 08:31 PM | #8 |
Got the tranny today, not sure what I'll do, I dont want to break it and I can run it in my scaler, but I spent a lot of time moving stuff around in my scaler to get the body to fit with the scx10 tranny.
03-21-2014, 12:13 PM | #9 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
I definitely would have picked a well built scx10 over the r2, but give it a shot anyway, maybe the HD version will hold up. The most common weak point of the R1 axles are the dogbones/cva. A common fix is to use tlt or wk knuckles and shorten cvds to fit. With these mods some guys have ran R1 axles on 4s. What is this straight axle conversion you are referring to? The portals are molded into the housing and they would be hard to get rid of without chopping up the housing.
03-21-2014, 03:32 PM | #10 |
i ended up not getting the axles, guy never showed up to meet me and then left the fb group that he was selling them on. i have a lead on a set of wraith axles now
03-21-2014, 06:02 PM | #11 |
I think you will be happy with wraith axles.
03-22-2014, 06:25 AM | #12 |
well now i have a choice for axles ,drinking and internet, not a good idea. so i now have a set of wheely king axles, wraith axles, and scx10 axles to pay for
tranmission/axle choices - Similar Threads | ||||
aluminum axle housing choices? | realsickclown | Axial SCX-10 | 51 | 01-07-2014 04:32 AM |
axle transmission choices? | tlsrcs | Newbie General | 16 | 09-16-2012 02:55 PM |
mirrored tranmission | dracbec | Axial AX-10 Scorpion | 4 | 04-18-2011 10:10 AM |
narrow axle choices? | Gen3_Teg_88 | General Crawlers | 10 | 05-20-2009 01:03 AM |
RC4WD R2 V2 tranmission | yotachump | General Crawlers | 19 | 11-13-2007 10:33 AM |
