03-19-2014, 08:05 AM | #1 |
Newbie Join Date: Mar 2014 Location: Norway
| RS 10 XT dual esc HELP!!
Hi, just got a rs 10 xt esc 50a dual, i put it in the crawler and Connect all Things needed, the servos for front and rear steering Works, but no response on the trigger so it won`t go forward or backward, but if i take the cables from the servos and put it in number 2 on the receiver and the cable from esc in number 1 or 3 on receiver so work everything but With an confusing error, i steer With the trigger and go for and back With the Wheel. so the trigger Works, but not if it set in number 2. what can be the problem? Last edited by yakima; 03-19-2014 at 04:45 PM. Reason: writing error. |
04-24-2014, 03:35 AM | #2 |
Quarry Creeper Join Date: Aug 2012 Location: Anchorage
Is the esc plug in the RX the proper direction? (Signal, pos, neg and such) Is all this gear all the stock gear? If yes just have to go over the directions again and make sure everything is correct. Is the tx stock as well or programmable? End points setup correctly? Does the esc need programmed after install or is it plug and play? Hope this helps you out. |
04-24-2014, 03:56 AM | #3 |
Pebble Pounder Join Date: Feb 2013 Location: Perth Australia
| Re: RS 10 XT dual esc HELP!!
Sounds like you need to calibrate the ESC to the TX.
RS 10 XT dual esc HELP!! - Similar Threads | ||||
Need help with dual ESC, dual servo, bec wiring | mudboggin3 | Electronics | 3 | 08-21-2012 10:23 AM |
Dual steer - Dual esc Cliffy | oldhippie | Duratrax Cliff Climber | 2 | 08-30-2010 09:47 AM |
My LCC MOA - Dual ESC, BL 17.5T, Dual 3S | axelram | Team Losi Comp Crawler | 47 | 06-26-2010 02:00 AM |
Futaba 9CHP setup for dual steering, dual esc | duartev | Electronics | 5 | 06-07-2009 08:58 AM |
