04-13-2014, 07:03 PM | #1 |
Pebble Pounder Join Date: Feb 2013 Location: Mid Missouri
| Looking for a Junfac driveshaft measurement |
04-13-2014, 08:03 PM | #2 |
Rock Stacker Join Date: Jan 2012 Location: Walters, OK
I had mip's, but had the same problem. I bought the junfacs and was able to clear the spur on a 90T. Sent from my iPod touch using Tapatalk |
04-13-2014, 08:16 PM | #3 |
The O.D is about 16 mm I would say the mip is about 21 Sent from my iPod touch using Tapatalk |
04-13-2014, 08:21 PM | #4 |
| I've already reassembled the driveshaft, but the other dimensions vary depending on honcho or dingo. You wouldn't have any trouble clearing your spur. I have had the same problem and these are a good solution to the Mip's Sent from my iPod touch using Tapatalk |
04-13-2014, 08:31 PM | #5 |
| Re: Looking for a Junfac driveshaft measurement
Thank you sir, that side by side picture is a huge help in itself. You are a wise & helpful soul, & the women undoubtedly swoon at your manly yet gentle ways. (E-ego fluffed ) |
04-13-2014, 08:39 PM | #6 |
Yeah sorry, I meant to take a picture of the drive shaft before I put the joint back on, but forgot and didn't feel like taking it apart again. But it is quite a bit smaller. The junfac doesn't have splines either, it is the half circle similar to the out puts on a transfer case or axle. I don't know what spur you have but I'm assuming it is bigger than 87T since it is the biggest you can fit. I ruined a 90T today because of the Mip's Sent from my iPod touch using Tapatalk |
04-13-2014, 08:47 PM | #7 |
Actually a 60T 32P, & front shaft is at a pretty hard angle, which made things unmanageable. If angle was better, could have probably done some minor grinding to make work, but as is, not happening. Thanks again. |
Looking for a Junfac driveshaft measurement - Similar Threads | ||||
Junfac gmade driveshaft question | chattinfarms | General Crawlers | 4 | 11-19-2013 11:29 PM |
Junfac Driveshaft | Steve Hipsley | Axial Wraith | 1 | 01-14-2012 02:05 PM |
