05-14-2014, 10:35 PM | #1 |
Newbie Join Date: Mar 2014 Location: CNY
| My Hydra-Steer System
Hey guys, I wanted a more scale look on my wraith! so took some measurements, hopped on Ebay, and started ordering the gear pump and cylinder! 10mm Bore x 20mm Stoke Cylinder ($20) Cheap chinese 6v Brushed Gear Pump ($6) I'm using a Dynamite Tazer 15t ESC ($40) to control the direction of the pump which is connected to the steering output of the RX. the fittings and hose im using are SMC 4mm LockLine fittings and 4mm ATP SURETHANE Hose ($24) Might upgrade the pump once I have everything where i want it, for a roll-type pump. Yes, This system actually works, It has enough force to turn the tires lock to lock on carpet. And is not slow at all. The pump only runs when the steering input is given. CW rotation of the pump = Left Turn, CCW rotation of the pump = Right Turn The only down fall of this system, is the wheels dont return to center, like a servo would. But for crawling, I can get use to this! Heres some pictures to give you an idea of what i've pieced together! 10mm Bore X 20mm Stroke Stainless Steel Cylinder with 4mm SMC LockLine Fittings Cheap Chinese 6v Gear Pump From Ebay The pump is Mounted where the RX box use to be, All of my electronics are relocated to the back, and the battery is moved to the front. Dynamite Tazer 15t ESC to control the gear pump motor. Ive been looking around for a small brushed boat ESC that has reverse. Can anyone lead me in the right direction??? |
05-15-2014, 04:25 AM | #2 |
Rock Crawler Join Date: Sep 2005 Location: Columbia, SC
Does it work? How fast is it? Can you take a video?
05-15-2014, 06:28 AM | #3 |
Rock Crawler Join Date: Feb 2014 Location: ?
| Re: My Hydra-Steer System
Next up air bag suspension?
05-15-2014, 07:01 AM | #4 |
Quarry Creeper Join Date: Jun 2012 Location: Next to you
For a esc have you looked at using a sidewinder micro.
05-15-2014, 11:49 AM | #5 |
Quarry Creeper Join Date: Nov 2013 Location: Huntsville
That is awesome. You are definitely thinking outside of the box. I didn't know that such small-scale hydraulic components were available. I wonder how we could work those cylinders into the suspension system?
05-15-2014, 12:25 PM | #6 |
How do you plan to bleed all the air out of the lines?
05-15-2014, 12:27 PM | #7 |
RCC Addict Join Date: Aug 2007 Location: Seattle
If it's not double ended and mounted like a real truck it's kind of meh. B for effort though |
05-15-2014, 02:49 PM | #8 |
Many 1:1s use a single ended ram
05-15-2014, 02:57 PM | #9 |
Sure do but they lose their cool factor when tractor parts are used.
05-15-2014, 02:57 PM | #10 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
| Re: My Hydra-Steer System |
05-15-2014, 03:19 PM | #11 |
I like overkill I guess. Got a 2200lb buggy with 3" psc parts.
05-15-2014, 03:29 PM | #12 |
05-15-2014, 03:31 PM | #13 |
Pebble Pounder Join Date: Mar 2014 Location: brainerd
05-15-2014, 05:55 PM | #14 |
Pebble Pounder Join Date: Nov 2006 Location: Tennessee
I am going to disagree that using tractor parts are not cool. Randy Torbett build this buggy in 2003 I think and used New Holland tractor axles and dominated the comps in the south with it. Sent from my Phoneamathingy |
05-15-2014, 06:26 PM | #15 | ||
| Re: My Hydra-Steer System Quote:
This is awesome. Nice work! I do want to see it in action though! | ||
05-15-2014, 06:52 PM | #16 |
Quarry Creeper Join Date: Mar 2013 Location: Armpit of Michigan
Been looking for scale hydraulic stuff for some time..... how do you find it?
05-15-2014, 07:08 PM | #17 | |
Rock Crawler Join Date: May 2012 Location: Washougal
I was running a single ended ram 14 years ago and never had any problems. About 6 years ago I went with a double only because I got a good deal on it. You don't get any more power with a double ended ram just a more balance steering lock to lock. Last edited by sam63; 05-15-2014 at 08:16 PM. | |
05-15-2014, 08:13 PM | #18 |
Ill be taking a video of the rig in action this weekend. I have a video of it working without the wheels on the ground, just a rough plumbed, half mounted deal. Heres the link - http://youtu.be/hCJ9-BWfO3o @Skerb, it is just as fast as a servo. @ C*H*U*D, the cylinder is put in a bath of hydraulic oil. the line from the pump at also put in hydraulic oil. the pump is ran, and then the lines are connected to the cylinder. yes i realize there is air bubbles in the lines in the pictures, and i knew someone would say something about it. @Diablo666, Ill defiantly look into that ESC. thanks for the info! @ DJjiz, Oh sorry, i forgot you are the master of all things crawling. let me go right out and buy a double ended cylinder! If you are looking for cylinders, look on ebay or amazon for pneumatic cylinders. if it holds air, its gunna hold liquid! be aware that certain types of seals in pneumatics do not like oil and will swell up from the oil. and for pumps, check out what the RC Submarine guys are using. thats where i got the pump idea from. and i will be switching my pump out for a Roll-type Pump (Peristaltic pump) as for hydraulic suspensions?! use the same concept, anything is possible if you can get your wife to let you order parts! Last edited by MAK_PrecisionRC; 05-15-2014 at 08:35 PM. |
05-15-2014, 08:48 PM | #19 |
03 was a long time ago and this isn't the first hydro setup but if there's room on a high horse I'd like a ride.
05-15-2014, 08:57 PM | #20 | |
Point of me posting this was, to get the idea that the resources are out there to make this happen, and for fairly cheap! You dont have to spend $600 on a "RC Heavy Equipment" Hydraulic system to make your own | |
My Hydra-Steer System - Similar Threads | ||||
Will Vanquish Axial High Steer Steering Knuckles make my truck steer tighter? | blue bronco | Axial AX-10 Scorpion | 3 | 08-09-2009 12:30 AM |
E-Fly 6Ch Flight System/Can this be modded to use with Clod Crawler 4W steer and dig? | TheHeadHunter | Electronics | 5 | 05-31-2008 03:50 AM |
High steer system ?? | JAKEF150FX4 | Tamiya Clod Buster | 17 | 11-15-2005 08:16 PM |
