Thread: custom cage
Old 09-11-2014, 08:41 PM   #1
Default custom cage
Im looking to build a custom chassis in the near future, what benders are everyone using to build theirs with? Are you using 3/8" solid rod? Or what size?
LapuaKrawler is offline   Reply With Quote
Old 09-11-2014, 08:56 PM   #2
Default Re: custom cage
Harbor freight has a nice one for the money and solid 3/16 seems to be the common size but I'll only run tubing. I don't build frames but the guys I work with say tubing is as strong as solid (except in bumper areas)
djjiz is offline   Reply With Quote
Old 09-11-2014, 09:59 PM   #3
I use a tubing bender from napa.
try this button,it will help you out.
http://www.rccrawler.com/forum/search.php
hotrodsonoma is offline   Reply With Quote
Old 09-11-2014, 10:14 PM   #4
Stevie Wonder is in charge of the rcc search.
Use google and add rccrawler.com to whatever you're looking for.
Old 09-11-2014, 11:32 PM   #5
Actually, add "site:rccrawler.com". That will ensure that you only get results from this site.
KJ10 is offline   Reply With Quote
Old 09-12-2014, 12:57 AM   #6
I never knew you could do that... Makes things a whole lot easier
-Dan
sickcivic95 is offline   Reply With Quote
Old 09-12-2014, 06:10 AM   #7
I was using the search feature on here last night and it is not as good as it used to be. Trying to search for two word searches and it wasn't helpful. Using "" around the words searched did not change the results. Thanks for the suggestions about google!
RaleighRCer is offline   Reply With Quote
Old 09-15-2014, 12:34 PM   #8
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Best bender I have found to date. Requires that it be held in a vice FYI: http://www.amazon.com/BAC-Industries...bac+rod+bender
Here are several chassis design templates to make building a chassis much easier as well.
Free Chassis Design Templates | Harley Designs
Harley is offline   Reply With Quote
Old 09-15-2014, 08:36 PM   #9
Awesome, thanks guys!! Ill check this out. I've seen some of the chassis' that you, Harley have made, i'm excited to try one or a few of them! Thanks!!
custom cage - Similar Threads
Custom cage lambo-27 1.9 Scale Rigs 14 07-13-2011 03:21 PM
