Thread: newb question
Old 10-05-2014, 07:17 PM   #1
Default newb question
not really sure if this is the right place to put this, but I just bought a used wraith, definitely needs some work, but i figured it would be a good way to get into the sport as I dig into it.
I got the electronics put into it, stock motor and electronics with a venom 4 channel 27 mhz radio with new batteries. I got a new charger and charged up the traxxas 3700 nimh battery that came with the truck. took it outside to play and it would jump to life then barely move or not at all. steering and throttle basically didnt work. then it would start working again and it would jump back and forth. im new to crawlers and rc stuff in general. does this sound like a bad battery or what? I brought the esc into a shop when I first got it and he plugged it into a comp and said it looked like it would work.
what should I do next?
ben10 is offline   Reply With Quote
Old 10-06-2014, 06:09 AM   #2
Default Re: newb question
It could be the receiver. I would bind the receiver to the transmitter then calibrate the esc. Also check all solder joints
novarider is offline   Reply With Quote
Old 10-06-2014, 09:03 AM   #3
How do i bind the transmitter to reciever and calibrate it? I checked all solder joints already. They are good.
Old 10-06-2014, 09:04 AM   #4
I have a guy I work with who is into rc stuff. He has a known good battery. I'm going to try that first.
newb question - Similar Threads
newb question meanbgreen Paint and Body 2 08-13-2011 07:59 PM
not a newb but have a question of newb stature Brandon88 Electronics 11 04-14-2010 08:53 PM
Newb question to beat all newb questions vinster888 Newbie General 3 12-29-2009 07:24 PM
Newb with a question spacecowboy Newbie General 3 01-18-2009 04:19 PM
