05-03-2016, 11:14 AM | #101 | |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
| Re: Ottsix TKO10 Quote:
05-03-2016, 01:24 PM | #102 | |
I can see both sides of this but I have to say that the majority of people that start to look to the aftermarket are going to know what a Revo end is and what it does long before they find out what a TKO10 is or at least real damn close to the same time. Links are so common across so many rigs that buying or building your own is more than likely one of the first things to happen to new trucks especially with such noodley stock links that immediately start showing their limitations. Plus, what does it take to go with the well known standard in the aftermarket and just put a line in the description, "Revo rod ends recommended". Don't stick with the stock design because it fits stock plastic inferior balls. That was the whole reason for producing this new axle in the first place, improvement. | |
05-03-2016, 07:50 PM | #103 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Ottsix TKO10 See, thats what I meant, if only I'd have been able to be that clear without being clouded by the frustration of having to something that I still think shouldn't need fixing.
05-07-2016, 07:21 AM | #104 |
RCC Addict Join Date: Apr 2011 Location: San Diego
| Re: Ottsix TKO10
These turned out a the perfect replacement for my boring axial stock housings. Used them with the sweet and narrow beefy beeftubes on my 1/6 leaf sprung willys with xr10 steering Last edited by Shinjari; 05-31-2016 at 10:36 PM. |
05-10-2016, 08:27 AM | #105 |
Newbie Join Date: Dec 2015 Location: Columbus
| Re: Ottsix TKO10
So I just picked up a set of these for my rig. I know that the upper links need to get shorter. Does anyone know by how much or how long should they be eye to eye for a 12" wheelbase.
05-10-2016, 09:13 AM | #106 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: Ottsix TKO10
Making the most out of that high pinion output. No links or driveshaft to get in the way |
05-10-2016, 10:32 AM | #107 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: Ottsix TKO10 |
05-10-2016, 10:57 AM | #108 |
| Re: Ottsix TKO10
Stock SCX10
05-11-2016, 01:07 AM | #109 |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
| Re: Ottsix TKO10
Are you thinking you need to adjust the wheelbase because of these housings are it's just needed at the same time? Cus the output on these is already angled up so in theory leaving it as is should work fine for these and will give the improved angle.
05-11-2016, 07:43 AM | #110 |
| Re: Ottsix TKO10 Its not to adjust the wheel base. The upper links get shorter because of the new trusses. To keep the axle rotation correct you change your upper links. I was just trying to save myself some guess work. My upper links are custom anyways so it's not to had to adjust myself.
05-11-2016, 07:49 AM | #111 |
| Re: Ottsix TKO10
Aaahhhh I assumed as they are designed to replace the stock units that the mounts were all designed to use stock length hardware etc.
05-25-2016, 05:32 AM | #112 |
Pebble Pounder Join Date: Aug 2011 Location: RF Moscow
| Re: Ottsix TKO10
1 in Russia Yesterday ordered forward delivery. Just ordered: Vanquish Aluminum Frame Servo Mount Silver For Axial SCX10 CMS Vanquish Aluminum Axle Panhard 3 Link Mount Silver For Axial SCX10 TKO-10 Rear Truss |
05-31-2016, 09:45 AM | #113 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
| Re: Ottsix TKO10
Has anybody used these for a narrow xr mod and if so what do you think? How much material did you have to remove. Sent from my iPhone using Tapatalk |
05-31-2016, 02:46 PM | #114 | |
Yes lots of people have, including me. When using TKO specific tubes, the only material you have to remove is the tangs where stock c hubs normally mount. You are replacing them with splined tangs that are part of the tubes. With the splines you retain the ability to clock the c hub and it keeps the c hub from rotating. | |
05-31-2016, 07:47 PM | #115 | |
Sent from my SM-T320 using Tapatalk | |
05-31-2016, 10:33 PM | #116 |
| Re: Ottsix TKO10
Wide means using xr10 universals in their factory width. Narrow means narrowing the axle to maintain roughly stock scx10 track width. So if you are trying to maintain stockish width. Get the narrow tubes, cut the housings, install wraith/xr10 chubs and knuckles and modify some xr10 universal tangs to fit in the locker. Look at my post on the previous page...it shows exactly how the narrow tubes work. Last edited by Shinjari; 05-31-2016 at 10:35 PM. |
05-31-2016, 11:16 PM | #117 |
| Re: Ottsix TKO10
Last question I think. Do you have to use the xr10 vvd's on the wide version or do you think the hd SSD ones will work as well. The xr 10's are getting hated to come buy Sent from my SM-T320 using Tapatalk |
06-01-2016, 10:50 AM | #118 |
| Re: Ottsix TKO10
I use cut down xr10 vvds. If you want to cut down wraith shafts, you'd need 2 long sides.
06-01-2016, 11:32 AM | #119 | |
Any xr10 universal/cvd would work. I typically use the Axial xr10 universals and cut them down and file new tangs. I know some vendors even provide this as a service. If you get wide tubes, then you dont have to modify the xr10 universals/cvds/vvds. If you want to maintain roughly stock scx10 width, from my experience you either have to modify them yourself or find a vendor who sells them already modified. | |
06-01-2016, 02:16 PM | #120 | |
Dlux Fab | |
Ottsix TKO10 - Similar Threads | ||||
Ottsix.com info+++++++++ | crawl-o-matic | General Crawlers | 5 | 04-25-2013 01:20 PM |
ottsix.com | crawl-o-matic | General Crawlers | 3 | 04-09-2013 04:36 PM |
Ottsix schism | losikid | Chit Chat | 9 | 05-20-2012 09:22 AM |
Welcome OTTSIX drivers | ScaleFreak93 | Chit Chat | 16 | 04-21-2012 06:29 PM |
