02-28-2016, 04:07 PM | #1 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
| Offset SSD D60 axle
The guys in tools and procedures helped me choose a bit to cut the pumkin for the steel tube. Still moking up. This will be my length. 8.5" hex to hex for now. Still need to drill and tap the housings / axle tubes / knuckles to have it all together. Also need to get a new set of wraith univerals to cut down ( stole these off my wraith for mock up) Last edited by ctrwannabe; 02-28-2016 at 04:52 PM. |
02-28-2016, 04:16 PM | #2 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
| Re: Offset SSD D60 axle
Interesting......... i will have to keep watching...... how do you think it will hold up with only that much of the tube in the housing?? |
02-28-2016, 04:23 PM | #3 |
Prob wont have time to mess with it again till next weekend. The axle tube is 1/2" into the pumpkin. Im planning on drilling / tapping for two 3mm screws per tube into the housing. Hoping it holds up. May make a brace from the pumpin to each tube.
02-28-2016, 04:34 PM | #4 |
I like the end result, I'd personally use a lathe for the job just to stay concentric.
02-28-2016, 04:50 PM | #5 |
Thanks man. No way is it perfect but i think itll work for me. If i had a lathe or mill id be using them but only have a drill press, dremel and hand tools.
02-28-2016, 06:36 PM | #6 |
Sign me up for a front narrow xr mod width axle. Really cool interested to see how it turns out.
02-28-2016, 07:00 PM | #7 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Danggg those look awesome! You could weld on a truss connecting the tubes and never have to worry about them coming out.
02-29-2016, 01:39 PM | #8 |
Rock Stacker Join Date: Jul 2015 Location: Fredneck
I'd take one in a drivers drop in a heart beat!! Nice work. |
02-29-2016, 04:03 PM | #9 |
It feels like 2004
02-29-2016, 05:14 PM | #10 | |
| Re: Offset SSD D60 axle Quote:
Love It! We need more of this again, enough of the cookie cutter store bought stuff. | |
03-01-2016, 09:04 PM | #11 |
| Re: Offset SSD D60 axle I fully understand that, and I find myself in the same situation right now. I'm anxious to see what you come up with as a truss. I have a set of these housings waiting for the exact thing to happen to them.
03-01-2016, 09:48 PM | #12 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
Cole always showin up doin cool stuff.
03-03-2016, 08:54 PM | #13 |
Oh, I like this!
03-04-2016, 07:42 AM | #14 |
Pebble Pounder Join Date: Dec 2015 Location: mishawaka
what size bit did you end up using to bore the housing?
04-07-2016, 05:56 PM | #15 |
thanks yall, brazinscalerc i used a 1/2" bit. tacocat, i think i will end up making a truss or something at some point here soon. this axle is going on a leaf sprung truck on my build here : Ctrwannabe's take on Fread Williams clampy I will show a little how i built this for anyone wanting to do there own, its not to hard at all. first i cut the tube to get the pumpkin by itself. next i centered it into a vice with a rod in the chuck to keep everything as plumb as possible, and then drilled the hole using a 1/2" forstner bit and drilled about 1/2" into the housing. next i took some 1/2" O.D. steel tube i picked up at home depo and cut it and played with length using the wraith uni's to get the width of 8.5" hex to hex i wanted. for the outter axle tube berring i went with a 5mmx10mmx4mm flange berring to support the axle shaft the I.D. of the tube had to be filed down a little so they would fit inside next i marked and cut then filed new flat spots on the universals to fit into the spool, and drilled/ tapped the axle tube to bolt to the pumpkin and c hubs. |
04-07-2016, 06:16 PM | #16 |
Killer!
04-07-2016, 06:47 PM | #17 |
I am liking this. Really thinking about giving it a go myself. I'd really like to do an offset front for my XJ build! Thanks for sharing! Cheers!
04-07-2016, 08:13 PM | #18 |
"GOD SPEED" Join Date: Oct 2014 Location: Wouldn't you like to know
Nice work this will be a great thread for those that want to attempt this. Great details. "GOD SPEED" |
04-07-2016, 08:58 PM | #19 |
Tie the truss into the pumpkin with a couple bolts and it will all hold up well. |
Offset SSD D60 axle - Similar Threads | ||||
1.55 Bronco, swb chassis, SSD D60 axles | Killa-Cotton | 1.5 Scale Rigs | 64 | 07-07-2017 09:23 AM |
Any had this problem with the ssd d60 housing? | Bmxreeves | Axial SCX-10 | 0 | 01-09-2016 04:13 PM |
Hub offset with SSD wide axle? | amped up | Axial Yeti | 3 | 01-06-2016 03:10 PM |
