Thread: Jato Rod End - odd balls?
Old 04-20-2016, 05:48 PM   #1
Default Jato Rod End - odd balls?
I got my first pack of Jato rod ends today (traxxas 5525) and four of the balls are different from anything I've seen before. Is this just a different design or are they mis-formed? I don't have calipers right now to measure with but a ruler shows they're about 8mm tall.
Normal on the right, oddballs on the left.
mikebecher is offline   Reply With Quote
Old 04-20-2016, 05:53 PM   #2
Default Re: Jato Rod End - odd balls?
Well I just answered my own question. Digging through some Google images shows that indeed some of the balls have a different design. Weird.
Old 04-20-2016, 06:23 PM   #3
Traxxas does that so you can fine tune their independent suspensions slightly by using different hollow balls. My Revo uses 2 or 3 different offsets on the front and rear-ends. I thought they were kind of strange when I first noticed them too.
dr frankenstyle is offline   Reply With Quote
Old 04-20-2016, 06:26 PM   #4
Natedog's Avatar
That's how they are supposed to be and I like them for fine tuning link placement (rod end mount width if double shear), great building and tuning tool.
Old 04-21-2016, 05:57 PM   #5
^ Same as above responses, I used the shorter balls with my links to fit in the lower link mounts on the AR-60 Axles.
Mike Flea is offline   Reply With Quote
Old 04-21-2016, 06:19 PM   #6
I like to use the taller balls when the link is in single sheer since the one end is too large for the rod end to slide off of. Saves me from using an additional flat washer that can get misplaced or forgotten.
WHITE-TRASH is offline   Reply With Quote
Old 04-21-2016, 06:22 PM   #7
That's what I was thinking they'd be good for, namely the steering tie rod ends. Those things always pop off if I don't have a washer under the screw head.
Old 04-21-2016, 06:27 PM   #8
Yup and the opposite end of them is s bit taller so it eliminates the need for a spacer too.
Old 04-21-2016, 06:39 PM   #9
amazing what a person can learn around here
thanks
cabron is offline   Reply With Quote
Jato Rod End - odd balls? - Similar Threads
rod end balls - alternative materials? subtlefly Axial SCX-10 0 08-21-2015 07:33 AM
Revo and jato rod end lengths hijakdgtr General Crawlers 6 08-04-2013 07:08 AM
will jato rod ends fix my ti rod problem? J-Fish Axial XR10 8 03-19-2013 06:56 PM
Jato rod end help Mortimer Snerd General Crawlers 6 04-27-2008 05:12 PM
