Thread: Axial yeti at crawling
Old 09-13-2016, 09:41 AM   #1
Default Axial yeti at crawling
Hey guys, I was looking to get a yeti but I was wondering how well it could crawl with the right parts and tuning.
Dawson4 is offline   Reply With Quote
Old 09-13-2016, 09:54 AM   #2
Default Re: Axial yeti at crawling
YouTube some video's the Yeti is a fun rig for all around fun... but I wouldn't consider it a good crawler.... it will do fine with the front diff locked (using silly putty). It will do fine for trailing, mild crawling, bashing, and u4rc racing...
tapped-out is offline   Reply With Quote
Old 09-13-2016, 10:08 AM   #3
Ok, cool. That is what I am kind of looking for. Something that is an all around kind of truck.
Old 09-13-2016, 10:31 AM   #4
I will concur with MILD crawling, locker up front, gear down on pinion, under drive rear axle adjust ground clearance , now speed running is poor, I put the 2 speed in . Running a sensored 3000kv tekin, it's OK, But I have gobs of fun as it is a torque monster.
HANG UP AND DRIVE !
mikemcE is offline   Reply With Quote
Old 09-13-2016, 11:00 AM   #5
i have 2 speed also. gives the yeti the opportunity to mild crawl / trail in first gear (Mr. Hide ) and 2nd gear for speed (Dr. Jekyll ).
If the Yeti couldn't do it with skill he will do it with power . I use Mamba Monster X with CC 3800kv. For me it's pure fun running this little monster
But i don't comp just freestyle.
magic_yeti is offline   Reply With Quote
Old 09-13-2016, 11:04 AM   #6
I bought the kit yeti added a few upgrades. For power plant, stock trans (IMO 2 speed is a waste of money) with a Holmes Hobbies 540xl motor and a castle creation mamba max pro esc will give all the speed you'll need and allowes the rig to crawl slooow.... running on 3s lipo.. many combinations of motor and esc's but I'm happy with above set-up.
Old 10-18-2016, 03:09 PM   #7
2-speed transmission, new tires, putty in the front diff, and my own custom sway bars.
DavidH is offline   Reply With Quote
Axial yeti at crawling - Similar Threads
Life of one YETI - Tom Frajer's Axial Yeti build log TomFrajer Axial Yeti 320 05-22-2017 09:01 PM
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti FastEddy Axial Yeti 13 04-21-2015 07:33 AM
Yeti Located - Axial Yeti bashing eunique Scale Videos! 0 02-12-2015 08:42 AM
Yeti Located - Axial Yeti bashing eunique Scale Videos! 0 01-09-2015 02:10 AM
