Thread: Your Trucks
Old 01-28-2004, 01:32 PM   #1
Default Your Trucks
Well since I seem to be the first user here, when people start to come, post your trucks and what mods they have on them
Mine:
-Juggernaut 2
-ball bearings
-Twin 13-turn Trinity Monster Mash Retros
-Pro-Line Hummer H2 body
-Super Rooster
-Savage shocks(not in pic)
-locked diffs
-ESC cooling fan
-about 8-9in. of articulation
jugg_crawler
jugg_crawler is offline   Reply With Quote
Old 01-28-2004, 01:57 PM   #2
Default Re: Your Trucks
Electric Digler:
XFactor converted to Electric
Super Rooster ESC
Magnetic Mayhem
JR XR3i 3 channel radio and receiver
Batteries run up front
Custom Cut TXT-1 Lightweight chasis
Custom aluminum tranny skid plate
TXT or Emaxx Tranny(usually TXT)
Emaxx Sliders Drive shafts
Savage 21 stub axle conversion
XFactor axles, locked Diffs and shaved bottom axle housings, modified output yoke for emaxx drive shafts
Custom Ackerman Drag Link and Tie rod steering / 4 Wheel steering with custom aluminum skid plates
Hitec 645 servos
XFactor Suspension, XTM shocks w/Trinity Blue Monster Springs and cantilever system, adjustable ride height
Custom made Suspension links, 15 inch wheel base, adjustable
RPM Clawz Wheels / BFT Associated Tires / cut new tread pattern
IMEX Jumbo Swamp Dogs, cut pattern / IMEX narrowed Diamond Wheels, Black
IMEX Jumbo Claw Dogs, cut pattern / IMEX narrowed Diamond wheels, Chrome
Custom Aluminum Boner Bar
Proline Jeep Bodies(3), Ford Bronco Body(1)
and way more!
Tight Squeez:
TXT-1
Custom suspension links 14.5 inch wheel base
Custom steering links/tie rod drag link configuration
Custom cut chasis 5.25 inches of belly pan clearance
Custom narrowed wheels
Custom cut tires
locked diffs
Rooster ESC
One stock motor, reverse wired
Emaxx slider shafts
Tmaxx shocks
DirkDigler is offline   Reply With Quote
Old 01-28-2004, 02:28 PM   #3
TxT-1 project "The One"
So far . . .
Custom cantilever links
Custom cut chassis to save on weight and add looks
Remounted cantilevers
Custom servo mount on axle
Custom link mounts
Bottom links mounted to top of chassis
Cut stock tires and Narrowed rims
Lengthened wheelbase
9 tooth pinions
Hitec 5645 digital MG
Soon to happen . . .
Lowered battery holder
Battery moved to front
Maybe tranny moved up and cutting done to bottom of chassis
And of course i got to get some electronics for this beast!
RcRock-Guru is offline   Reply With Quote
Old 01-28-2004, 03:20 PM   #4
Guest
Posts: n/a
Jobu's X-factor
-13 tooth CB, 52 tooth Savage spur gear
-XTM tuned pipe, Cooling head
-Offroad air intake
-Stone fuel filter with primer ball.
-Custom front bumper
-Savage hubs
-XTM sliding cluch
-Eight shock set up
-4 wheel steering
-Modified servo mounts
-Slightly extended wheel base
-Locked front and rear
-IMEX Jumbo Kongs with 1/4"of the foam removed
-Dodge Power Wagon Body
Working on extending my driveshafts.
Old 01-28-2004, 03:21 PM   #5
Guest
Posts: n/a
Hey guys, you know you can host your own pics at www.cardomain.com
It's free and I think has unlimited space. I have at least 70 or pics with em.Just an FYI
Old 01-28-2004, 04:09 PM   #6
Awsome! Keep them coming.
jugg_crawler
Old 01-28-2004, 08:56 PM   #7
R.I.P. Chip
jason's Avatar
If you guys email me pictures and descriptions of your trucks I will put them in the featured rigs section
jason@rccrawler.com
jason is offline   Reply With Quote
Old 01-28-2004, 11:58 PM   #8
XFACTOR's Avatar
hey my name is Ryan(XFACTOR) and this is my X-FACTOR!
MODS...
xtm wheelie bar
imex jumbo swamp dawgs and chrome diamond rims
4 blue xtm schocks for 8 schock setup
proline jeep body
alluminium link rod mounts
allumium gearbox side plates.
btw..i am wating on my allumium stuff and xtm axle adapters when they arrive in the mail, ill update the pics! should be tomorrow or early next week! so heres the pics...
XFACTOR is offline   Reply With Quote
Old 01-29-2004, 08:58 AM   #9
The Wheels Keep Turning
kevinlongisland's Avatar
work in progress:
http://www.nitroextreme.com/cars_tru...36/img1797.jpg
http://www.nitroextreme.com/cars_tru...36/img1791.jpg
http://www.nitroextreme.com/cars_tru...36/img1787.jpg
kevinlongisland is offline   Reply With Quote
Old 01-29-2004, 08:59 AM   #10
WORK IN PROGRESS 2:
http://www.nitroextreme.com/cars_tru...36/img1831.jpg
http://www.nitroextreme.com/cars_tru...36/img1842.jpg
it's finally done. (or at least running). i still have to make or get nice steering links for it. and my battery mount, radio tray is make shift but perfectly functional.
Old 01-29-2004, 01:05 PM   #11
Nice trucks! Keep them coming.
jugg_crawler
Old 01-31-2004, 05:04 AM   #12
the gecko maxx
skyjacker_rc_club is offline   Reply With Quote
Old 01-31-2004, 06:35 AM   #13
Awsome! Hey kevinslongisland how did you make those mounts and the tranny on your E-Maxx? I looks like it has almost as much articulation as my Juggernaut! The Gecko clod looks awsome too!
jugg_crawler
Old 01-31-2004, 02:34 PM   #14
jugg_crawler
which mounts? for the tranny/motor, i just modified the stock plate so i could mount the motor lower to the chassis for lower CG. I still have to make nice upper shock mounts for the savage shocks. The ones on there i ROUGH cut out of a cheap plastic snow sled.
Old 01-31-2004, 04:48 PM   #15
The Crawlers:
Skitzo Pajero
Tamiya Pajero MTW
Full Rc4wd Bearings
Hotrodical Paint
Hobbitech wheels
Locked diffs
Mag Mayhem
14t pinion
Custom rear setup
Maxx drive shaft
Bug!-y
Tyco Canned heat-durango
Custom front suspinsion
Hacked chassie and beetle body for wieght and clearance purposes
Skids by me
I have a total of $21.50 into it
Entire vehicle used as a curb feeler
Pajero #2-still building
Tamiya pajero
Pull master motor
custom gear reduction
Clod buster body
Custom rear suspinsion
Clawdawgs on chrome dagger wheels
Still pondering what else I can do to it
TL-01 Bogger
Tamiya TL-01
Custom (hacked ta' pieces) chassie
Custom suspinsion
Clodbuster body (also hacked)
Speed gems pro 17t (amber)
TTR adjustable motomount
Intellispeed 16t reverse speed control
TF-4 radio system
Locked diffs
Brass bushins and bearings (bushings don't freez up in mud :P )
It likes mudd but rocks are cool to
Gimp
Tamiya Bruiser
Portal axles
frame narrowed 3/4"
Tranny in back insteed of front
4 link suspinsion
IMEX pullers
Still building it 8O
I also have a HPI nitro MT that hits the rocks occasionaly
Highmark is offline   Reply With Quote
Old 01-31-2004, 06:23 PM   #16
Awsome! Thanks for the info kevinslongisland. I think that truck is very nice and so is your Clod. Highmark your Pajero's and Bruiser sound awsome. Could you post some pics?
jugg_crawler
Old 01-31-2004, 06:49 PM   #17
Thanks! the bruiser and #2 jero are still beeing built so there at the shop :( but here's a some of the other trucks...
Skitzo
Mudder (old pic-lots done sence then)
Bug!-y
Old 01-31-2004, 07:31 PM   #18
R.I.P. Chip
jason's Avatar
I wish they made those BFG tires for our bigger rigs...
Old 02-01-2004, 01:52 AM   #19
XFACTOR's Avatar
hey is that red pajero a mini z? and howd u get that much travel out ofit? or is it like that standard?
Old 02-01-2004, 06:33 AM   #20
Very nice! How does the Pajeero perform? I might buy one so if you could give me some feedback and wht parts you would suggest buying that would be gratly appreciated.
Thanks,
jugg_crawler
