03-21-2019, 07:01 PM | #1 |
Quarry Creeper Join Date: Jul 2011 Location: Seattle
| Force RC Hammerjaw Upgraded Front Drive Shaft Options?
Bought my girlfriend one of these, and with mild driving, we were in 3wd in a matter of minutes... Is there an upgrade front driveshaft option for this rig? It is not usable as is being this fragile. Too risky to take it on a trail day. Thanks for any assistance!
03-22-2019, 09:08 AM | #2 |
RCC Addict Join Date: Jan 2011 Location: Wheat Ridge
| Re: Force RC Hammerjaw Upgraded Front Drive Shaft Options?
Was wondering about this rig and if they were any good. Depending on the size of the output and input shafts you should be able to use any standard 5mm drive shaft to replace the factory ones. Pics would help |
03-22-2019, 09:22 AM | #3 |
Rock Crawler Join Date: Mar 2015 Location: Waltham
You might have some luck with this thread: Force RC Northwood and Hammerjaw discontinued? Also, from what I've gathered, you may get more life out of your front axle shafts if you adjust the endpoints on your radio. Turning down the steering rate will limit your steering angle, but may prevent the drive cups from chewing through the axle shaft. It's worth a shot. |
03-22-2019, 06:20 PM | #4 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
Out of the box the steering dual rate is set too high and the dogbones can bind, causing breakage. Replacement axles may be difficult to find. These axles are wider than moat other HSP-made axles, so the Redcat E10 and Gen7 axles won't fit. You're probably going to need to use Wraith compatible axles, but the Hammerjaw axles are a larger diameter where they fit into the lockers, so to use an Axial compatible axle you'll need to swap out the spool too. |
03-22-2019, 10:38 PM | #5 | ||
| Re: Force RC Hammerjaw Upgraded Front Drive Shaft Options? Quote:
Edit: I was going to post a video of what I have up until now in my video edit of my review, which is basically just my intro, and all the running fotoage (Probably 5 minutes), But I haven't posted here in a while, and can't for the life of me remember what the video posting protocol is here.... Last edited by NFA Fabrication; 03-22-2019 at 11:09 PM. | ||
03-25-2019, 05:53 AM | #6 |
the only way to post a youtube video here is to link it, or embed it. To embed it, start your video on youtube, then right-click and select "copy embed code". Paste that into your post, and you'll have about an 80% chance of it working. For some reason, around 20% of the time it'll just post text instead of embedding the video.
Force RC Hammerjaw Upgraded Front Drive Shaft Options? - Similar Threads | ||||
Force RC Northwood and Hammerjaw discontinued? | TIME MACHINE | 2.2 Scale Rigs | 18 | 04-15-2019 07:10 AM |
drive shaft options | krank22 | General Crawlers | 12 | 03-05-2014 05:01 PM |
so many drive shaft options? | steveo 561 | Axial SCX-10 | 2 | 05-16-2012 08:01 PM |
wk drive shaft options | Burge | HPI Wheely King | 11 | 06-04-2008 03:25 PM |
drive shaft options????? | rcjeepbuilder | HPI Wheely King | 14 | 02-01-2008 03:11 PM |
