04-08-2020, 09:38 PM | #21 | ||||
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Traxxas Big Bore in 80mm? Quote:
Wrong, that is exactly what I posted above yesterday..... There are two reasons I did this. One, as mentioned is to get an 80mm with a very nice shock that they do not make. Two which is the big one, is to maintain a low ride height for sidehilling or climbs, instead of going with a really soft spring on the longer shock. It prevents from getting a bunch of unloading and some wonky COG setup. Just raising your shock position does not change how much it will unload, it will still unload a full 90mm, you need to limit it. Its a great way to tune a performance rig but not always for everyone. I like my comp rigs planted, dont need much flex at all. Last edited by Joshs4x4toyz; 04-08-2020 at 09:41 PM. | ||||
04-09-2020, 03:04 AM | #22 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
| Re: Traxxas Big Bore in 80mm? So you're NOT using spacers to adjust ride height as previously suggested, you're using springs |
04-09-2020, 05:31 AM | #23 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
Listen you are making this really complicated when it is not. The OP asked how to shorten his shocks. The length of a shock is its total extended length. Placing a spacer under the piston inside the shock body reduces its total extended length so results in a shorter shock.
04-09-2020, 07:04 AM | #24 | |
With just that advice alone his trucks ride height will be higher than necessary and more than likely have collision between axles and frame. If the proper solution of spring weight tuning and understanding suspension is to complicated for you, feel free to block me, I'm not here for the elitist attitude crowd, I'm here to help, learn and share | |
04-09-2020, 10:44 AM | #25 |
RCC Addict Join Date: Aug 2005 Location: SoCal
Traxxas makes (possibly made, not sure if still in production) a 80mm shock TRA2659 I would recommend ordering a rebuild kit with them as mine the bladders were dried up. |
04-09-2020, 10:57 AM | #26 | |||
Well, if youre here to learn, dont let ignorance and pride get in your way. Not sure how else to slice this or what youre missing. I guess without the experience you will not see what it does. This or limiting straps is the best performance way to do it. Softer springs can get you the same ride height, but will result in excessive unloading. Like I said, its not for everyone. | |||
04-09-2020, 05:21 PM | #27 | |
No pride or ignorance here mate, I'm playing with toy trucks at 41 which I'm about to go do and enjoy my ONE day of sunshine FML. Cheers! | |
Traxxas Big Bore in 80mm? - Similar Threads | ||||
traxxas big bore help | Matty221133 | Axial XR10 | 6 | 12-03-2013 02:48 PM |
traxxas big bore | marco.m | Axial XR10 | 3 | 09-12-2012 08:27 AM |
traxxas big bore??? | bigemike | Axial SCX-10 | 1 | 08-21-2012 09:11 PM |
3.5 traxxas big bore | Grimreeper | General Crawlers | 5 | 04-29-2010 09:09 AM |
