06-22-2020, 01:54 PM | #1 |
| HW1080 mount
Servo tape is just not cutting it. I need a way to solid mount the HW1080 to the side pan. Anyone know of a bracket/mount that fits the HW1080 to allow it to be hard mounted?
06-22-2020, 01:58 PM | #2 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: HW1080 mount
I made one with my 3d printer, clips on to esc then zip tied for security. Currently it's designed to mount the esc on its side with a single screw holding it into the chassis of my rr10. Very specific mount right now but could easily be adapted for a different way to mount the mount to something. Sent from my SM-G960W using Tapatalk |
06-22-2020, 02:01 PM | #3 | |
Rock Crawler Join Date: Aug 2007 Location: Dela-where?
| Re: HW1080 mount Quote:
This sounds cool. Any pics? | |
06-22-2020, 02:18 PM | #4 |
| Re: HW1080 mount
At work right now, I'll try and link some later Sent from my SM-G960W using Tapatalk |
06-22-2020, 02:40 PM | #5 |
| Re: HW1080 mount
I use 3M Dual Lock. For all my ESCs Waterproof and durable Hang up and Drive |
06-22-2020, 02:49 PM | #6 |
| Re: HW1080 mount
I found this on Thingiverse if your able to print one. You still have to use servo tape, but the sides hold it in place good. Sent from my iPad using Tapatalk |
06-22-2020, 03:03 PM | #7 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
| Re: HW1080 mount
I've been using Scotch Outdoor mounting tape for year to mount esc's, switches etc. When you first place it doesn't seem that strong but after it sits it grabs harder. Also easy to remove. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 can also get it at Walmart in the hardware isle.
06-22-2020, 03:18 PM | #8 |
| Re: HW1080 mount
e6000 a dab will do ya
06-22-2020, 03:32 PM | #9 | |
That would work but I don't have a 3d printer. I could use a couple of zip ties to secure the ESC to the mount. Anyone willing to print me a half-dozen (6) of those? Send me a PM. https://www.thingiverse.com/thing:3681466 Last edited by Inspector86; 06-22-2020 at 03:45 PM. | |
06-22-2020, 05:31 PM | #10 | |
What RC? | |
06-23-2020, 07:36 PM | #11 | |
Newbie Join Date: Jun 2020 Location: New York
Check eBay. It is meant for TRX4 as the mounting holes fit perfect. With this you would need to drill 2 holes. Sent from my iPhone using Tapatalk | |
06-24-2020, 02:17 PM | #12 |
| Re: HW1080 mount
I need to mount the HW 1080WP to the TRX4 chassis with a simple mount like the one on thingyverse. I'm not interested in any tape or glue solutions and I don't need a fan so the one on ebay is over priced for what I want. This might be the excuse I need to finally buy a 3D printer.
06-24-2020, 03:54 PM | #13 |
| Re: HW1080 mount
Use E6000 or Goop. Holds very strong yet can be cleanly pealed off if you need to swap electronics.
06-24-2020, 05:39 PM | #14 |
Newbie Join Date: Feb 2016 Location: Mount Vernon
| Re: HW1080 mount
I designed and 3D printed this for my Element frame. Not sure if the measurement between the rails is the same for a TRX4. It traps the ESC, no glue or tape. |
06-24-2020, 06:25 PM | #15 |
Quarry Creeper Join Date: Dec 2012 Location: okc
| Re: HW1080 mount
try shoe goo instead of tape, let it dry overnight it should hold great for you, can still be removed with a little force if you need to.
HW1080 mount - Similar Threads | ||||
How is the AE-2 as a crawler ESC compared to HW1080? | Smokin' Joe | Electronics | 7 | 05-08-2020 09:27 AM |
HW1080 in Ascender | Myndefuk | Vaterra Ascender | 7 | 02-21-2020 05:03 PM |
Hw1080 and stock micro servos | Bigbush979 | Traxxas Crawlers | 13 | 03-08-2019 01:47 PM |
Can HW1080 drive two motors in parallel? | Inspector86 | Electronics | 11 | 12-30-2018 08:41 PM |
HW1080+Promodeler 470... BEC necessary??? | AnimalHippie | Electronics | 36 | 08-03-2018 08:33 AM |
