Thread: Crawlmaster in a Capra
Old 06-24-2020, 08:45 PM   #1
Default Crawlmaster in a Capra
Any one running a Crawlmaster Expert 20T in a Capra?
Opinions would help me out.
Thanks,
z381472 is offline   Reply With Quote
Old 06-25-2020, 12:59 AM   #2
Default Re: Crawlmaster in a Capra
Got a 16t with a 12t pinion and it's extremely good. Low end is good as well.
Sent from my Pixel 3 using Tapatalk
Crawler Cads is offline   Reply With Quote
Old 06-25-2020, 04:41 PM   #3
Thank you for the info.
I am new to the hobby, Could you explain the advantage of changing the pinion rather than running a 20 T motor?
Old 06-25-2020, 04:54 PM   #4
I run a HW1080 paired with a crawlmaster sport 13T, 11T pinion on 3s in my capra, wheelspeed as you need and smooth at startup. Next i will test a 10T pinion.
Right now i would go with a 16T crawlmaster sport using 3s, for more drag brake and torque. On 2s i think the 13T is the sweet spot. using 3s 13T or 16T would be my choise.
magic_yeti is offline   Reply With Quote
Old 06-26-2020, 12:47 AM   #5
If you're constantly throttling the power to the 20t motor it'll likely heat up some. Using an appropriate motor that'll be allowed to throttle a bit more will reduce that stress / heat.
Old 06-26-2020, 08:10 AM   #6
A 16T Crawlmaster with lower gearing will have more torque, better low speed control, better brake hold, and run more efficiently. Running a 20T Crawlmaster with the stock gearing just makes things slower without all the other added benefits.
svt923 is offline   Reply With Quote
Old 06-28-2020, 04:26 PM   #7
Plus it will run hotter.
Inspector86 is offline   Reply With Quote
Old 06-29-2020, 03:59 PM   #8
I would normally have recommended a 20T but having had a 16T CM Pro in my Capra I'd agree that's the one!...
stimpy is offline   Reply With Quote
Crawlmaster in a Capra - Similar Threads
VFD Capra...Can I Still Call It A Capra? mjensen Axial Capra 107 11-20-2021 03:56 AM
My Capra dezracer99 Axial Capra 15 05-12-2020 10:42 AM
My Capra pfray Axial Capra 4 05-12-2020 07:52 AM
Capra 2.2 mccarsones Axial Capra 23 10-19-2019 03:19 PM
