10-03-2020, 11:41 AM | #1 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
| Axial axle threads? Which die? Anyone cut adtl. threads before?
Greetings! Looking to add threads on my Axial universals. Reason is I'm running RC4WD narrow hubs and woild like to avoid running a bunch of washers/spacers between the nut and the hub. Has anyone done this before? What is the thread? I believe the size is M4. Thank you. Sent from my SM-N960U using Tapatalk |
10-03-2020, 02:00 PM | #2 |
| Re: Axial axle threads? Which die? Anyone cut adtl. threads before?
I added a few threads to my VS410 axles, just takes a M4 die and some patients. Since I don't have any fancy holding fixtures, I used my drill to hold the axle shafts while I put the die to them. It is slow going but not terribly hard. |
10-03-2020, 07:57 PM | #3 |
| Re: Axial axle threads? Which die? Anyone cut adtl. threads before? Thanks for the response. Did you use M4 x 0.7mm?
10-05-2020, 08:35 AM | #4 |
| Re: Axial axle threads? Which die? Anyone cut adtl. threads before? |
10-13-2020, 09:13 AM | #5 |
Axial axle threads? Which die? Anyone cut adtl. threads before? - Similar Threads | ||||
Front mounted Axial trans - where are the pics/threads? | pixelnate | General Scale Talk | 9 | 03-16-2012 08:12 AM |
Definitive ESC, MOTOR, and BATTERY threads - RCC's top tech threads! | badger | Electronics | 3 | 07-02-2011 03:51 PM |
axial link threads | greasemonkey85 | Axial AX-10 Scorpion | 4 | 02-04-2009 07:46 PM |
Axial 40 series 8hole wheels Too many stripped bead threads... | TheHeadHunter | Tires and Wheels | 4 | 06-11-2008 10:02 PM |
Definitive Radio, Power Wiring, BEC and Servo Threads-- RCC's Top Tech Threads! | JohnRobHolmes | Electronics | 0 | 11-08-2007 07:09 PM |
