10-21-2020, 08:22 AM | #1 |
Rock Crawler Join Date: Aug 2020 Location: In The HIVE
| Axial SCX10 iii Fast Eddies Bearings Discrepancy??
So I’m currently rebuilding axles and most parts of my axial SCX 10 three and I ordered some bearings from fast eddies which I get for all my vehicles and both of the bags that I got had 4 bearings that were not sealed anybody Know if these are 4 bearings that are actually used in some part of the vehicle let me know I’ve attached pictures I’ve never seen a fast Eddie bearing that’s been bad please, let me know! Buzz Buzzz.....
10-21-2020, 08:36 AM | #2 |
| Re: Axial SCX10 iii Fast Eddies Bearings Discrepancy??
If I remember that build, those are internal bearings and are surrounded by grease. Hang up and Drive |
10-21-2020, 08:49 AM | #3 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
^^ Mike's got it. These should be 7mm ID x 14mm OD x 3.5mm wide. They are used on the AR44 axle diff locker. Axial doesn't supply them with seals either. |
10-21-2020, 09:03 AM | #4 |
Thanks for the responses guys I do remember bearings being like that back in the 90s on certain builds I just hadn’t seen one in the last couple years that I’ve been back into RC so thanks again for that appreciate it... buzz buzzz....
10-21-2020, 10:14 AM | #5 |
Quarry Creeper Join Date: Aug 2020 Location: Springfield
Huh, the ar60 axle uses sealed? Are the axles tighter on an AR44? |
10-21-2020, 12:13 PM | #6 |
RCC Addict Join Date: Mar 2019 Location: Hemet
They said ar44 but these are actually for the ar45 portals on the 10.3 and they’re open Sent from my iPhone using Tapatalk |
10-21-2020, 01:25 PM | #7 |
Thanks for the correction on the axles Friker 🙏🏼
10-23-2020, 03:54 PM | #8 | |
| Re: Axial SCX10 iii Fast Eddies Bearings Discrepancy?? Quote:
Looking at the manuals for the SCX10 ii and the SCX10 iii, the bearing is the only part common to the ring and pinion assembly of the AR44 and AR45 axles. I know the gearing is different with the portals so I guess that's why there are no other common parts. | |
11-01-2020, 06:44 AM | #9 | |
11-01-2020, 07:38 AM | #10 |
Rock Crawler Join Date: Apr 2020 Location: Drums
Just out of curiosity, why are you changing out the bearings on your 10/3 so soon? The 10.3 hasn't been out that long. I'm fairly new to crawling so just wondering how soon bearing wear out.
11-09-2020, 06:40 PM | #11 |
| Re: Axial SCX10 iii Fast Eddies Bearings Discrepancy?? I bought the rig used and I put a good 40 hrs on it and im changing the axles to solid aluminum so im going with new bearings and of course I clean the old ones and save them for future projects if they are in good shape! thanks.... BUZZZZ....
Axial SCX10 iii Fast Eddies Bearings Discrepancy?? - Similar Threads | ||||
Axial SCX10 III without portals | Paul_crawl | Axial SCX10 III | 69 | 11-24-2020 02:14 AM |
axial scx10 iii | Mikearm71 | Electronics | 4 | 05-14-2020 10:55 AM |
Fast Eddy,, Axial Yeti bearings | CKRC Hobbies | CKRC Hobbies | 0 | 08-07-2014 11:47 PM |
Fast Eddies Scale Adventure | d_1 | Arizona | 1 | 12-12-2013 11:29 AM |
