08-01-2020, 07:01 PM | #1 |
Newbie Join Date: Jul 2020 Location: Russia
| Axial SCX10 III without portals
SCX10 III without portals should be?What do you think?
08-01-2020, 07:07 PM | #2 |
Quarry Creeper Join Date: May 2017 Location: Bellevue
| Re: Axial SCX10 III without portals
Yup Sent from my iPhone using Tapatalk |
08-01-2020, 07:53 PM | #3 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
Been waiting for a non-portal version to come myself. Word of warning, say anything negative about portals around here and you'll get your head chewed off. |
08-01-2020, 08:41 PM | #4 |
| Re: Axial SCX10 III without portals |
08-01-2020, 11:53 PM | #5 |
RCC Addict Join Date: Mar 2019 Location: Hemet
I think it would be great to offer a non-portal version. My only thing is, it drives me nuts when people want to bash them because “they’re not scale” At the end of the day we’re driving very expensive toys and I want mine to have more ground clearance lol Sent from my iPhone using Tapatalk |
08-02-2020, 08:18 AM | #6 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
I asked the same question a few days ago and got nothing. I just don't like them on a jeep. They work well and do give extra clearance but I'd rather see something more like the scx2 axles under the jeep.
08-02-2020, 08:33 AM | #7 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
A few of us have put these bodies on vs410s. It’s a great fit. Otherwise the vanquish axles should work on a 10.3 with a little bit of link tweaking. Axial will eventually have a straight AR45 axle out, which will be similar to a 10.2 axle just offset. |
08-02-2020, 08:46 AM | #8 |
| Re: Axial SCX10 III without portals Hot damn that looks good
08-02-2020, 04:53 PM | #9 | |
| Re: Axial SCX10 III without portals Quote:
For example, I've got a long-term project for which I just picked up a UMG10 body. I want it to be more scale-accurate, so portals are a must. Likely using my VS4-10 chassis and Element transmission. At some point I will need either TRX-4 or SCX10.3 portals to complete it. I'll bet there are others that will be building custom rigs that use them as well. | |
08-02-2020, 05:13 PM | #10 | |
08-03-2020, 12:15 AM | #11 |
I have a pair of 10.2 Rock Jocks I’d like to use on my 10.3. Is this not possible/not recommended as the 10.3 axles are offset?? Sent from my iPhone using Tapatalk |
08-03-2020, 07:52 AM | #12 |
| Re: Axial SCX10 III without portals The biggest problems you will run into with a centered housing on the 10.3 is getting the upper link and driveshaft to clear the transmission as they angle in towards the middle of the axle. It would likely take a small diameter driveshaft, a little trimming, and some experimenting with upper link mounting but it doesn't look impossible.
08-03-2020, 08:08 AM | #13 | |
Hey cool good info thanks. I’ll take a closer look at it all. I do have a small driveshaft somewhere apparently. Not sure where though, but my wife keeps telling me I have one Sent from my iPhone using Tapatalk | |
08-04-2020, 11:43 AM | #14 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Axial SCX10 III without portals What did you use for body mounts on the chassis?
08-04-2020, 01:54 PM | #15 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
| Re: Axial SCX10 III without portals I'm betting he's using the mounts from Knight Customs. https://www.myminifactory.com/object...unt-set-127379 |
08-06-2020, 08:28 AM | #16 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
I too, want a non-portal offset solid front axle
08-06-2020, 09:16 AM | #17 | |
Like the rest of you I’m anxious for an axial offset front axle. I think it will basically be a plastic version of the vs410 axle with an axial style pumpkin. I hope a multi piece axle is eventually available with clockable/upgradable chubs. Quote:
Luckily the mounts from the scx10iii work on the vs410 chassis up front. Only difference is one screw holding the mount instead of two, unless you want to drill, but I don’t think it will be an issue. On the rear I’m just using magnets. | |
08-17-2020, 12:12 PM | #18 |
Pebble Pounder Join Date: Feb 2016 Location: Shelby
If you want to run non portal axles and don't want to pony up vanquish 💰ssd has an ocp option based off ar44's.
08-20-2020, 07:10 AM | #19 | |
Newbie Join Date: Oct 2019 Location: W. Hartford
The offset on the ar45 axles looks similar to vanquish offsets, and the one attempt I've seen with VS4-10 + SSD offset axles here on RCC was unsuccessful due to driveline & link interference. Different chassis I know, but similar enough to make me concerned that similar issues would be hit | |
08-20-2020, 07:52 AM | #20 |
The ssd is the same offset as ar45 where vanquish is offset to the other side no? If I remember correctly you can't run vanquish ocp axles with the trail king chassis because of this. Sent from my LM-Q720 using Tapatalk |
Axial SCX10 III without portals - Similar Threads | ||||
Axial SCX10 III Jeep Gladiator | Paul_crawl | General Scale Talk | 29 | 08-21-2020 09:29 PM |
axial scx10 iii | Mikearm71 | Electronics | 4 | 05-14-2020 10:55 AM |
