11-01-2021, 11:49 PM | #1 |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| How far can two ratios be?
I am planning out a custom build right now and i want to use two different axles..one has a gear ratio of 2.76 and the other has 3.75. Is that too far apart? If so, how close do they need to be? Plese enlighten me on axle ratios lol. ______________________________________ AR60 VS410 TRX4 Sport coming soon.. Veterans deserve a whole month too... Last edited by ScaleLifeNewbie; 11-02-2021 at 12:03 AM. |
11-01-2021, 11:53 PM | #2 |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
| Re: How far can two ratios be? https://www.calculatorsoup.com/calcu...calculator.php I'd recommend not going over 40% OD. What are the axles? |
11-02-2021, 12:01 AM | #3 | |
| Re: How far can two ratios be? Quote:
______________________________________ AR60 VS410 TRX4 Sport coming soon.. Veterans deserve a whole month too... | |
11-02-2021, 12:02 AM | #4 |
I wanna be Dave Join Date: Sep 2019 Location: US
I wouldn't even go higher than 35% front OD. The VS4-10 Phoenix, with it's VFD-Twin, has a 'high' of 33-34% (the 'low' is 6.5%), which is the highest I've seen. Something else to think about...if you'll be crawling over lava rock, you'll want an even lower OD (probably no higher than 12-15%). Otherwise, that lava rock will "eat" your rear tires faster than you can chew through a Liliha Coco Puff. ~ More peace, love, and kindness would make the world a much better place |
11-02-2021, 12:02 AM | #5 |
| Re: How far can two ratios be? |
11-02-2021, 12:07 AM | #6 | |
11-02-2021, 12:08 AM | #7 | |
Never mind... they're out of stock. Last edited by DRED805; 11-02-2021 at 12:12 AM. | |
11-02-2021, 12:17 AM | #8 | |
| Re: How far can two ratios be? Quote: Edit: i wonder if i could fit some ar44 gears in the IFS...i could get closer to the k44. I dont mind running some OD. ______________________________________ AR60 VS410 TRX4 Sport coming soon.. Veterans deserve a whole month too... Last edited by ScaleLifeNewbie; 11-02-2021 at 12:23 AM. | |
11-02-2021, 12:25 AM | #9 | |
The only leaf spring conversion I saw in a quick search is the BRX01 boom racing axle. Maybe look into that... I don't know anything about it. and there's a leaf conversion kit for this axle...https://www.crossrc.us/shop/cross-rc-hc4-hc6-rear-axle/ Width is close. Could be something to look into. Last edited by DRED805; 11-02-2021 at 12:30 AM. | |
11-02-2021, 12:37 AM | #10 | |
I was thinking ar44 underdrive up front to bring it bsck down, but i can only find 9.5% by VP. granted i didnt look too deep yet. Edit: no i would need overdrive to bring it up to the k44. ______________________________________ AR60 VS410 TRX4 Sport coming soon.. Veterans deserve a whole month too... Last edited by ScaleLifeNewbie; 11-02-2021 at 12:45 AM. | |
11-02-2021, 01:02 AM | #11 |
Ok i think i have an idea. The rear axle is 30% faster than the front. If i install the Stealth X trans, i can OD the front 12.8%. That makes the rear only spin 17.2% faster. Then install the SSD Ar44 OD and get 10% more OD. that brings the rear down to only spinning 7% faster. I think thats more manageable than 30%. Or i could just say screw scale and run rear links or front/rear leafs. ______________________________________ AR60 VS410 TRX4 Sport coming soon.. Veterans deserve a whole month too... |
11-02-2021, 02:07 AM | #12 |
You do NOT want the rear spinning faster then the front...not even 1% faster. Every time you try to climb...especially a step...you WILL flip it. ~ More peace, love, and kindness would make the world a much better place |
11-02-2021, 02:53 AM | #13 |
There are ar44 leaf mounts on shapeways.
11-02-2021, 06:20 AM | #14 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Element diffs are center pinion, ar44 gears are high pinion, so they won’t mesh when installed in an element housing. The element trans is a good choice, and several companies (hot racing, team knk) make higher ratio o/d gear sets to get up to 25% I believe. Another member was discussing this same idea a few weeks ago, my recommendation was to use an SSD pro44 rear housing and jec leaf mounts if possible. Not 100% sure the jec mounts are available, or even compatible with the pro44, but it’s worth a look. |
11-02-2021, 07:19 AM | #15 |
i dont see why you just dont use a elemint rear axle too you can leaf spring any axle not a big deal heck i put a trx4 axle on to a rig with leafs befor i realised it was a real bad idea with the portals and all to much leverage on the leafs lol but it can be done
11-02-2021, 01:03 PM | #16 | |
I really like the looks of the K44 and it will match really good with my body choice, where as an ar44 or element doesn't. ______________________________________ AR60 VS410 TRX4 Sport coming soon.. Veterans deserve a whole month too... | |
11-02-2021, 01:06 PM | #17 | |
If i was to choose a different axle, id go for a Pro44. Just for scale looks. ______________________________________ AR60 VS410 TRX4 Sport coming soon.. Veterans deserve a whole month too... | |
11-02-2021, 02:37 PM | #18 |
RCC Addict Join Date: Mar 2019 Location: Hemet
Rather expensive option… but a 2.low transmission provides 30% overdrive to the front axle. And it’s not scale at all Sent from my iPhone using Tapatalk |
11-02-2021, 04:40 PM | #19 |
| Re: How far can two ratios be? I totally forgot about the 2.Low. That's a good idea. Still cheaper than my other Idea..VFD. A 3 gear is really scale either though.
11-02-2021, 05:24 PM | #20 |
Would something like this work? I could run some OD while I'm at it also. https://www.amainhobbies.com/rc4wd-t...zxqseqtzqxactz |
How far can two ratios be? - Similar Threads | ||||
What are the RATIOS? | person123 | Losi Mini-Rock Crawler | 0 | 01-01-2010 03:53 PM |
Gearbox ratios? | Jamus | General Crawlers | 16 | 01-14-2006 10:24 PM |
gear ratios | eric113 | Traxxas Crawlers | 9 | 12-01-2005 11:58 PM |
Ratios chart | Rikpal | General Crawlers | 0 | 02-18-2005 07:11 AM |
Ratios Qs | Rikpal | Tamiya Clod Buster | 2 | 01-27-2005 07:35 AM |
